01-16-2013, 09:15 PM | #1 |
Pebble Pounder Join Date: Apr 2012 Location: BritishColumbia
| Rednecks Rampage Ridge Crest Build!
Okay i have had this rig for a month and a bit now ran it stock unshure how i wanted the build to go. With people building up bashers running 4 cells to people building comp crawlers were do you with go with one. Today i started my first step. I picked up a new pinion, spur gear, servo extension and a wraith stage one link kit. heres the progress so far ( please note well i was doing this did harleys mod and flipped shock towers and battery placement) Here it is stock- heres a picture of the parts i started to use. |
01-16-2013, 09:18 PM | #2 |
| Re: Rednecks Rampage Ridge Crest Build!
I got half the link kit on but man axial kits know how to make your fingures sore with all there hard plastic you can also see the difference it made. |
01-16-2013, 11:35 PM | #3 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
Do you not get a spur and pinion in the kit? What motor are you planning on using and are you gearing this up to be a basher?
01-17-2013, 12:04 AM | #4 |
I did get a spur gear and pinion i am just changing them for more speed and tunning. I will probably end up running a rx8 eventually if i run it as a basher even though that is beyond over kill. Since i had the day off i finished what i could. i still have to go pick up some new shocks hopefully in the next day or 2. I also took all the plastic skid platting off the stock body as you will see in the last picture. |
01-18-2013, 01:09 PM | #5 |
So today i went to my local hobbie store and picked up a set of gmade piggy back shocks. i threw 2 on but still have to find some time for the other 2. Overal i was impressed with the gmade shocks but into building the second one, i stripped the top shock tower and now have to order a new sprue set. its attatched but still is waiting on the new cap to fill it with shock fluid.
01-18-2013, 01:09 PM | #6 |
| Re: Rednecks Rampage Ridge Crest Build! |
01-18-2013, 04:01 PM | #7 |
Rock Crawler Join Date: Aug 2012 Location: Etowah
I am sure that you will like those shocks better than the factory squish sticks!
01-19-2013, 03:36 AM | #8 |
In my opion the stock axial shocks are disposable.I like the gmade but after a long day of work I miss threaded the shock cap building the last one causing a massive leak, thank goodness they sell replacement tops
01-20-2013, 10:25 PM | #9 |
Newbie Join Date: Jan 2013 Location: Denver
I love the look of those shocks and can only imagine how much better they work.
01-21-2013, 11:56 AM | #10 |
there nice shocks i had a hell of a time asembling them one leaks and the other i stipped the top cap (i am a rookie lol). -thread up date- Waiting on posts to mount my new body and waiting on funds to order from vanquish. |
01-27-2013, 10:03 PM | #11 |
finally put on my proline body, still needs a few more coats. i hope in another week i can put in my vanquish order |
Rednecks Rampage Ridge Crest Build! - Similar Threads | ||||
ridge crest rock crawler face lift | brent_gifford | Axial AX10 2nd-gen | 3 | 12-12-2012 10:39 PM |
Project Rampage - Class 3 Custom Tube Frame TTC Build | monkeyracer | 2.2 Scale Rigs | 31 | 04-30-2011 07:36 AM |
stupid rednecks | 93 FORD BRONCO | Chit Chat | 6 | 09-27-2009 05:43 PM |
Drunk Rednecks | Tonsa | Chit Chat | 6 | 01-01-2006 11:22 PM |
