Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX10 2nd-gen
Thread: Stock steering knuckle question
Old 04-24-2014, 10:17 AM   #1
Default Stock steering knuckle question
What are the 2 extra flanges on the back side (rear of vehicle side) of the steering knuckles for? I hate not being able to figure out the function of something and none of the replacement knuckles have them.
kduchow is offline   Reply With Quote
Old 04-24-2014, 11:09 AM   #2
I believe the knuckles are used on other models that use those steering links instead of the high clearance links
Sent using lipo power
jaymann is offline   Reply With Quote
Old 04-24-2014, 11:57 AM   #3
Default Re: Stock steering knuckle question
Thanks. That pointed me in the right direction. The XR10 uses them to route the steering link behind the axle, with the tie rod still being in front.
Old 04-25-2014, 10:32 AM   #4
Cut em off. They are for rear steer on a different model.
CG3
chipgibbs is offline   Reply With Quote
Old 04-25-2014, 08:07 PM   #5
The knuckles and C-hubs currently used on the AR60 axle were originally used on the XR10, which used a factory BTA setup for the tie rod.
I leave the one in place that contacts the axle housing at full steering lock. It makes a good steering stop and keeps the universal shafts from binding.
meatmonkey is offline   Reply With Quote
Old 04-25-2014, 09:00 PM   #6
Norton's Avatar
No need to cut them off, leave it be. They will not hurt your setup. Unless you get universals.
Norton is offline   Reply With Quote
Old 04-28-2014, 01:49 PM   #7
Natedog's Avatar
Yes, leave them on they make great stops and your universals won't bind and still lots of steering.
Stock steering knuckle question - Similar Threads
stock steering question BigSki Vaterra Twin Hammers 6 03-15-2013 03:25 PM
Stock ax10 steering question venom08 Axial AX-10 Scorpion 13 11-10-2012 12:44 PM
Steering knuckle HECKER Newbie General 1 07-13-2012 07:24 PM
HR steering knuckle question all_scaled_out Axial SCX-10 1 02-14-2011 02:31 PM
inside tyre touches steering knuckle / steering linkage murky123 Axial SCX-10 4 10-06-2010 04:46 PM
