09-01-2014, 02:36 PM | #1 |
Newbie Join Date: Jun 2014 Location: Eldorado
| just picked up a deadbolt
Hey guys. So my neighbor had an ax10 and we worked out a trade on my rs10...I have a 3s battery and it will run it but is it safe to do so? It already had a good twist on the rear center driveshaft so I ordered a steel on for the back. I just wasn't sure of I can run a 3s safely or I'd I need to stick with a 2s
09-02-2014, 02:34 PM | #2 |
Quarry Creeper Join Date: May 2010 Location: Vic B.C Canada
| Re: just picked up a deadbolt
I believe to run a 3s you need to disconnect The built in bec and run a stand alone bec. Sent using lipo power |
09-08-2014, 01:04 PM | #3 |
Rock Stacker Join Date: May 2014 Location: Germany
Yup I heard, the same, and thats what I plan on doing before I run 3s |
09-17-2014, 10:27 AM | #4 |
Newbie Join Date: Jan 2014 Location: Murrieta
Everything you read says not to push the stock ESC past a 2s. Get a CC BEC and then you're golden.
09-29-2014, 02:20 PM | #5 |
I don't think I fully understand what a CC BEC does...It looks like it just deliver's lower power to the servo?
01-11-2015, 09:07 PM | #6 | |
Newbie Join Date: Feb 2014 Location: Rancho Santa Margarita
| Re: just picked up a deadbolt Quote:
I can run a 3s lipo to my esc. The esc will only send 6 volts to the servo. What if I want to run 7.4 volts to the servo ? If I run power straight to the servo from the battery, it'll will run at over 11 volts and it'll burn out. With a BEC, I can run power to it from the battery and set the voltage it sends to the servo to any setting I like up to the max voltage of the battery. | |
just picked up a deadbolt - Similar Threads | ||||
just picked up a CR-)1 | gunatrytocrawl | Tamiya CR-01 | 10 | 09-17-2011 12:58 PM |
Picked one up.... | paintballer9876 | XTM Crawler | 25 | 03-28-2010 10:30 PM |
Just picked up a WK. | Swampwalker3 | HPI Wheely King | 3 | 09-16-2009 12:18 AM |
Picked up a CR-01! | lt. | Tamiya CR-01 | 2 | 08-18-2009 07:07 AM |
Just picked up my first CR-01 | FreshMeat | Tamiya CR-01 | 11 | 02-14-2009 11:10 PM |
