Binding help So this is a brand new AX10 Deadbolt that I put Integy CVDs in and STRC knuckles before it ever even touched the ground. I know Integy isn't the best but I wouldn't think that there is much that could go wrong with the CVD other than durability. Anyway, it binds up when you turn the steering past 50% lock each way. I tried it with the tires off and it still binds as well. I lubed the CVDs and no better. Any ideas? Click the link for a video. 4A85D251-2873-4219-BDFE-EDBD55F175D0_zpsc70ncogg.mp4 Video by Xplocivic | Photobucket |
Re: Binding help reset your end points on the steering |
Re: Binding help Using that logic then I would have to give up about 50% of the steering. Nope, that's not it... |
Re: Binding help Send the integy parts back? Just a thought. ;) |
Re: Binding help Its not only durability, its working angle and your epa's are exceeding it. Sounds like either limiting the steering or getting some different shafts is the ticket... |
Re: Binding help Quote:
Your servo is pushing those CVD's past the usable limit. Either turn down the end points or get universals. |
Re: Binding help I'm taking the Integy crap out of it. I got them so I would have more steering not less, so turning the EPA down is counter-productive to what I am trying to do. Thanks for the replies... |
Re: Binding help That is a pretty good amount of steering. also are you gonna be running that fast when you turn? They work ok, But honestly turning down the ST/rate a touch will help. |
Re: Binding help Had the same issue when I installed my new knuckles till I realized I had a dumb a** moment and only installed one bearing in the new knuckles |
