Turning with Universals versus dog-bones So, I just got done putting the Axial Universal Joint axles in the AX10. Took it out in the backyard on my little test course. Wow! Night and day difference in turning capability. Other than going to the 55T motor, and hi-torque servo, this is probably the most noticeable modification that I've done so far! The one thing I did notice though, is that with the increased turn that I get at the wheels, the tires are now rubbing the springs on the Losi 4" crawler shocks that I put on last week. Just slightly, but enough to hear it. I still just have the stock, RTR radio. Not sure I can limit the servo throw with that? |
Re: Turning with Universals versus dog-bones I don't believe you can adjust EPA's with the stock radio. About the only thing you can do, other than getting a different radio, is fabricate some steering stops. With spring cups that aren't captured, you'll likely lose a cup or two when the tires rub. |
Re: Turning with Universals versus dog-bones @Solitaire - good idea on the stops. I think I can whip something up pretty easy there. Should hold me over until I get a new radio rig. |
Re: Turning with Universals versus dog-bones The stock radio does allow you to adjust steering throw. |
Re: Turning with Universals versus dog-bones With the stock Axial radio, you can dial down the steering with the "Steering D/R" knob. |
Re: Turning with Universals versus dog-bones Quote:
No more worries of lost spring cups.. |
Re: Turning with Universals versus dog-bones JeepinDoug spring cups for scaler .......... FTW........"thumbsup" |
Re: Turning with Universals versus dog-bones adjust your EPA on the steering. I did it myself on my ridgecrest(hopefully same radio). I tune it depending on the size of tires I run very easily |
Re: Turning with Universals versus dog-bones Another option is to widen up your stance with hubs or wheel wideners, depending on how wide it is already? It will be more stabil as well... |
