02-18-2017, 07:55 PM | #1 |
Newbie Join Date: Jun 2016 Location: United States
| axle housing upgrades? Thoughts? Help
Hi all, I don't think you guys know this funny story, my ax10 deadbolt fell through some thin ice, in my lake, and it sank, I was able to recover it, the esc had water in it, the battery was nearly drained (yes it was a lipo) the servo was full of water, all that I lost was really tire foams! Anywho, I had a question, my next set of upgrades was going to be either vanquish ar60's or I just found Boom racing Phat axles ar60s in steel, which one is better? The vanquish is $80/housing while the Phat axle is $45/housing. I think steel is better but are they good? My next upgrades were going to be HOT racing alloy trusses and metal axle gears, and MIP's and then I would have a bullet proof ax10 deadbolt. Currently it looks sweet. Grr well I assume they are good as they are out of stock, any idea when they will be available? Thoughts on this question/matter would be appreciated! Thanks -Spence Last edited by Spencecrawler; 02-18-2017 at 07:57 PM. |
02-19-2017, 09:28 AM | #2 |
| Re: axle housing upgrades? Thoughts? Help
I love my boom phatties the weight of the axle plants the rig on any terrain I've used a few different aluminum versions of the ar60 and I like the booms way better and steel glides across the rocks were aluminum gouges and hangs up I got the gray diff cover and the gray blends nicely with the natural color of the steel I would like to see them loose the fill and drain holes on the diff cover as the catch on obsticles every now and again I would also get some pinnion shims to as one of my phatties has a bit more play than a brand new axial housing not a big deal as the plastic weres out fast and ends up with more slop the steel won't were so its a one time deal Last edited by ferp420; 02-19-2017 at 09:33 AM. |
axle housing upgrades? Thoughts? Help - Similar Threads | ||||
Using a front axle housing on your rear axle | nstn8 | Axial XR10 | 2 | 10-25-2011 07:32 AM |
Thoughts on upgrades | GrndLvls Brain | Newbie General | 4 | 01-08-2010 08:39 PM |
Axle build items. thoughts welcome. | Timmahh | Axial AX-10 Scorpion | 4 | 08-24-2008 12:31 PM |
