08-21-2017, 03:40 PM | #1 |
Pebble Pounder Join Date: Apr 2015 Location: New England
| Thoughts on HR vs incision spool lockers
Hi guys my ax10 deadbolt is pretty built rn, it's got a lot of upgrades, and a top tip I found out for the stock axle housings if the c hub screws strip out the plastic, put some hot glue on the screw and jam it in there and twist it a little and let it dry it holds up until the next time you remove the screws. But anywho, the only stuff that is stock left is the axle housings rear lockouts and the stock axial aluminum bevel gears and the plastic housing lockers. I am exploring the HR spool vs the incision one, the HR Is $2 or so less... Since I'm cheap, would the stock used bevel gears fit the spools? I feel like the lockers will fall apart before the gears will, the stock locker is ok but it involves plastic in the driveline... Thanks -Spence Last edited by Spence; 08-21-2017 at 03:47 PM. |
08-22-2017, 05:25 AM | #2 |
Quarry Creeper Join Date: Dec 2009 Location: Strafford, NH
| Re: Thoughts on HR vs incision spool lockers
I run the HR spools or FI spools from locked up RC. Never had a problem with them. The stock gears will fit.
08-22-2017, 07:46 AM | #3 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
| Re: Thoughts on HR vs incision spool lockers Quote:
So far I have sheared a pair of CVD's but no issues on the locker. Last edited by Ditchrat; 08-22-2017 at 07:50 AM. | |
08-24-2017, 11:37 AM | #4 |
Pebble Pounder Join Date: May 2014 Location: SF
if it fit the budget get the grip fab locker with the set screws. super nice i think you can get 2 for $50 bucks. GripFab "Grip-Lok" Locker!! |
08-25-2017, 08:41 AM | #5 |
| Re: Thoughts on HR vs incision spool lockers |
08-28-2017, 08:45 AM | #6 |
I have a hr spool and a incision spool both have the same amount of slop the incision has some nifty machine work that i cant quite figure out what its for i also have the fi spools and the dead lock spools i realy dont see a differance in how they work however the fi and deadloc spools are thicker and th3 deadlocs are only like $12 so there my new go to locker im not noticing any differance in function or performance however the fi and d3adloc are heavyer so better on the front and the hr and incision spools are lighter still stronge enuff to do the job but i think would be better on the rear i dont have any first hand exsperiance with the other brands or styles
Thoughts on HR vs incision spool lockers - Similar Threads | ||||
Incision Spool Screws | Truckmechanic304 | Axial SCX-10 | 3 | 04-02-2016 08:52 AM |
Tell me about Spool Lockers | GodSpeed999 | Newbie General | 37 | 02-22-2015 04:31 PM |
ax10 spool lockers | TRA3905 | Axial AX-10 Scorpion | 9 | 10-23-2008 09:38 AM |
Tru-Spool Lockers!! 40.5 grams of parkerized hardened 4130 chromoly | JAM MaxAmps.com | Axial AX-10 Scorpion | 17 | 05-09-2008 11:43 AM |
