01-20-2019, 05:00 PM | #1 |
Newbie Join Date: Jan 2019 Location: Washington
| Axial ax10 deadbolt speed upgrade
I've got an axial ax10 deadbolt that I'm wanting to get some more speed out of. I'm planning on converting it into a monster truck eventually. What would you guys recommend for good speed upgrades? I'd prefer to not go brushless if i can help it. Thanks in advance.
01-21-2019, 10:10 AM | #2 |
| Re: Axial ax10 deadbolt speed upgrade
How fast do you want to go and how much do you want to spend and how are you planning to use it is it a basher is it a crawler is it a race truck With no other info i would say a 20t motor and 3s battery and bigger tires and sway bars Idealy i would say buy a smt10 chassie links and sway bars Steel ar60 axles 3.8 wheels 40 series tires Mip driveshafts 2200-3500kv 1/8th scale brushless motor Momba monster x esc Some big bearing knuclkles |
01-21-2019, 07:08 PM | #3 | |
| Re: Axial ax10 deadbolt speed upgrade Quote:
01-23-2019, 10:57 AM | #4 | |
You can also play with the pinnion gears to get more speed but again your motor wont last very long geared up realy high maybe 2 or 3 teeth on the pinnion any more than that and you would have motor temp issues becareful i just had a motor flame on cause it was geared to high also lost a esc for the same reason flame on lol thats why i say get the right motor If you decide to stay brushed get a 550 can motor it will have more torque and last longer | |
09-12-2019, 07:44 AM | #5 |
Newbie Join Date: Sep 2019 Location: Paradise
Just get something designed to go that fast. The handling of the scale chassis is going to be severely limiting. Adding power just finds weak parts. Every part you upgrade will just move the fail point to the next weak link.
Tags |
ax10, power, speed |
Axial ax10 deadbolt speed upgrade - Similar Threads | ||||
2-speed transmission upgrade using Axial Yeti parts | fyrstormer | Axial SCX10 II | 10 | 04-23-2020 12:52 AM |
ax10 Deadbolt steering upgrade | DieselStrom | Axial AX10 2nd-gen | 8 | 11-04-2014 10:48 AM |
Axial Ax10 Deadbolt and AE-5 | Geck0Jeep | Axial AX10 2nd-gen | 2 | 10-01-2014 08:54 AM |
Axial AX10 Deadbolt | Lentsnh2012 | General Crawlers | 4 | 10-29-2013 12:10 PM |
