Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX10 2nd-gen
Thread: Axial ax10 deadbolt speed upgrade
Old 01-20-2019, 05:00 PM   #1
Default Axial ax10 deadbolt speed upgrade
I've got an axial ax10 deadbolt that I'm wanting to get some more speed out of. I'm planning on converting it into a monster truck eventually. What would you guys recommend for good speed upgrades? I'd prefer to not go brushless if i can help it. Thanks in advance.
Reynolds0808 is offline   Reply With Quote
Old 01-21-2019, 10:10 AM   #2
Default Re: Axial ax10 deadbolt speed upgrade
How fast do you want to go and how much do you want to spend and how are you planning to use it is it a basher is it a crawler is it a race truck
With no other info i would say a 20t motor and 3s battery and bigger tires and sway bars
Idealy i would say buy a smt10 chassie links and sway bars
Steel ar60 axles 3.8 wheels
40 series tires
Mip driveshafts
2200-3500kv 1/8th scale brushless motor
Momba monster x esc
Some big bearing knuclkles
ferp420 is offline   Reply With Quote
Old 01-21-2019, 07:08 PM   #3
40 series tires
Mip driveshafts
Momba monster x esc
I don't plan to bash it really, maybe some small jumps, nothing crazy, so I'm thinking more"race" i mean i don't want huge speed, just more than the 15mph it does right now, maybe 25-30ish.
Old 01-23-2019, 10:57 AM   #4
Ok 20t motor on 3s and sway bars should get you around 18-20 mph im guessing because the stock 27t is getting you about 15 mph the motor wont last long though realy to hit 30 your ether gona give up all your low end torque or your gona have to go brushless
You can also play with the pinnion gears to get more speed but again your motor wont last very long geared up realy high maybe 2 or 3 teeth on the pinnion any more than that and you would have motor temp issues becareful i just had a motor flame on cause it was geared to high also lost a esc for the same reason flame on lol thats why i say get the right motor
If you decide to stay brushed get a 550 can motor it will have more torque and last longer
Old 09-12-2019, 07:44 AM   #5
Just get something designed to go that fast. The handling of the scale chassis is going to be severely limiting. Adding power just finds weak parts. Every part you upgrade will just move the fail point to the next weak link.
cmontgomery is offline   Reply With Quote
Tags
ax10, power, speed
Axial ax10 deadbolt speed upgrade - Similar Threads
2-speed transmission upgrade using Axial Yeti parts fyrstormer Axial SCX10 II 10 04-23-2020 12:52 AM
ax10 Deadbolt steering upgrade DieselStrom Axial AX10 2nd-gen 8 11-04-2014 10:48 AM
Axial Ax10 Deadbolt and AE-5 Geck0Jeep Axial AX10 2nd-gen 2 10-01-2014 08:54 AM
Axial AX10 Deadbolt Lentsnh2012 General Crawlers 4 10-29-2013 12:10 PM
