Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX10 2nd-gen
Thread: What do you all think of the aluminum front axle
Old 08-19-2018, 01:16 PM   #1
Default What do you all think of the aluminum front axle
Hey I have a AX10 Deadbolt completely stock. I want some parts for it but they are hard to find kinda. Will this aluminum front axle work? https://www.hobbytown.com/complete-b...23493s/p241258
Snowflake is offline   Reply With Quote
Old 08-19-2018, 10:40 PM   #2
Default Re: What do you all think of the aluminum front axle
Don't buy that axle, I've heard all kind of horror stories about integy stuff, from broken links to destroyed gears. If you want an aluminum axle look at vanquish, or ssd.
What parts are you looking for? The AX10 deadbolt uses most of the same parts as the axial wraith. In fact, they use the same axles, transmission and driveshafts. If you want narrower axles either try the original scx10 axle or the newer ar44.
Dezertdirt is offline   Reply With Quote
Old 08-19-2018, 11:34 PM   #3
I just want some more weight without adding weight for the sake of adding weight. I don't think it is heavy enough stock. Good to know most wraith parts work.
Old 08-20-2018, 11:14 AM   #4
Natedog's Avatar
Yep, pass on that Integy junk, low grade stuff almost always.
You' don't need a ton of weight down low, my old Honcho worked great, steel beeftube up front, stamped steel beadlocks (RC4WD makes some great ones), CI foams, small 4.19 Ripsaw tires.
Old 08-20-2018, 12:09 PM   #5
Maybe look into getting some aluminum c-hubs and get either Dlux knuckles or vp knuckle and rc bros weights (not sure if the rc bros weights are still being made). I've run both, Dlux is heavier. Either will add weight in the right place. Or I've also heard good things about beeftubes. If you don't want want to spend that much you can just add weights to the wheels.
here are some links.
Dlux
Dlux Fab
Beeftubes
https://www.amainhobbies.com/beef-tu...bt004b/p578526
this just one of many places you can get beef tubes
RC bros Look around you might be able to find a set used.
wheel weights
there are lots of threads on this look around. sort of a summary: it is ok if the rig is meant to go slow, if it is meant to go fast you will wreck bearings and other components. keep it about or below 3 oz per side.
Old 08-21-2018, 01:17 AM   #6
Kk cool thanks!!
Old 10-22-2018, 08:54 PM   #7
I joined the Band!
or just get the VP AR60 housing. that adds weight and they look good.
personally, i do what is said above, but i did run the VP first
Wraith / Yeti Axle V2 Black Anodized - Vanquish Products
xlostonex is offline   Reply With Quote
Old 10-29-2018, 12:01 PM   #8
I got sick of the threads backing out of the plastic AR60's on my old Gen 2 AX-10 (Since been sold). I wanted to re-work it on a budget since I wasn't using it much. I picked up the Xtra speed aluminum axles housings. Fairly cheap (like $48 shipped for both), and they worked well and went together easy.
mewalsh100 is offline   Reply With Quote
Old 11-13-2018, 08:56 PM   #9
im using the xtraspeed steel axles. they are heavy and well made for the price. allmy vp stuff fit with no issues
kbclamper is offline   Reply With Quote
Old 01-07-2019, 01:42 PM   #10
I have vanquish Rock jocks front and rear on mine i love the scale look they give and add a little weight where its needed.
NastyNate is offline   Reply With Quote
What do you all think of the aluminum front axle - Similar Threads
Aluminum rear axle? talento Axial Yeti XL 5 07-02-2017 06:38 PM
Need some help with aluminum axle C's rocpede Tamiya TLT Crawlers 10 12-19-2015 01:57 PM
