10-11-2019, 09:29 AM | #61 | |
| Re: topher builds a Capra Quote:
I do have the first round of parts for the "future" Capra arriving tomorrow! Man, that Valley of Fire looks like a ton of fun! I added it to my "need to go places"! I don't know if I will make it though, so looking forward to seeing all of the awesome pics & videos! | |
10-14-2019, 10:26 AM | #62 |
Quarry Creeper Join Date: Nov 2008 Location: The land of bagged milk
Great build thread! Lots of good tips! Just saw your video on YT!
10-23-2019, 05:16 AM | #63 | |
Newbie Join Date: Mar 2018 Location: Bulgaria
Topher, what is your impressions so far with the over drive gears? Are you still using the SSD overdrive? What about the Boom racing overdrive for ar44? I want to purchase one of the 2 but will wait for your input Last edited by Veygr; 10-23-2019 at 05:27 AM. | |
10-23-2019, 08:35 AM | #64 | |||
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
I’ve not tried the boom racing or the HR sets in the Capra but I do have each in other rigs and neither has failed. Iirc the HR gears only have 3 holes whereas the locker for the Capra has 6 but they should line up. The boom racing gears come with a keyed locker which I’m not sure fits the Capra, it likely will, but I’m not aware of anyone that’s tried those yet. Quote:
10-24-2019, 12:13 AM | #65 | |
I know they are not designed for the Capra. Its on my head Thank you also for the nice thread and excellent pictures. Do share more when you have | |
10-24-2019, 11:04 AM | #66 |
Rock Stacker Join Date: Apr 2019 Location: Reno, NV
Excellent thread topher. Cannot wait for your next update. For myself, I typically climb slick rock and sandstone in and around the Sierra Nevadas. Most conditions are high traction...To say the least. For batteries, I am alternating between my Protek 3S 4100 and Helios 3S 1500 packs. Plus of the larger 4100 pack is that it adds weight to the front (for uphilling) with a downside of the added weight being a tad high (for sidehilling). Hoping to see some brass weighted portals componentry for the Capra soon. Would you mind going through your thoughts on batteries? Last edited by Still Bill; 10-24-2019 at 11:23 AM. |
10-24-2019, 03:34 PM | #67 | ||||
Second from left with the RC4WD Wranglers for tire'/wheel win! Quote:
Brass is over-rated and used in excess these days as a bandaid to proper rig setup, a little goes a long way to fine tune it though. | ||||
10-24-2019, 06:03 PM | #68 |
| Re: topher builds a Capra |
10-24-2019, 06:15 PM | #69 | |
There is 1/4 lb brass portal covers and tungsten hangers arriving tomorrow for my capra. I can add 1/2 lb in tungsten if desired but I doubt I'll need it since it's all below the axle centerline. | |
10-25-2019, 08:27 AM | #70 | |
Quarry Creeper Join Date: May 2019 Location: Knoxville
Thanks in advance! | |
10-25-2019, 08:41 AM | #71 |
As another point of reference, I ended up using either 1 or 2, 7mm i.d. x 0.1mm shims to push the spool/ring gear away from the pinion, no shims on the pinion. It was still tight at the time of install, but I took the driveshaft off a couple days ago to see how the SSD OD gears were doing and (after a few dozen packs) the front end now spins nice and freely with no excess play.
10-26-2019, 10:14 AM | #72 |
Thanks!! I'll see what the LHS has in stock before I open it up to install them.
10-27-2019, 08:33 AM | #73 | ||
My brother was in town for the last few days so we got out to play with the tiny trucks. Clip below, more scenic than technical, and some pics. Quote:
I don’t recall, it wasn’t many though only one maybe 2. What J said sounds about right. J, good to know about the wear too. I feel like mine has only gotten smoother since the first pack as well. | ||
10-27-2019, 11:46 AM | #74 |
Red Rocks is beautiful! Have to get back there in 2020.
11-06-2019, 02:05 PM | #75 |
Newbie Join Date: Aug 2018 Location: DRESDEN
Thanks so much for the this. The shift fork was really messing with me. Excellent job!! Sent from my SM-S767VL using Tapatalk |
11-07-2019, 05:07 PM | #76 |
Got back out with the goat and a little different set up. Stuck with the 90mm shocks and changed to a more firm rear spring as well as adding vp 2.2 steel disc weights up front for some extra weight. It climbed a bit better but I don’t like all the rotating weight so I’ll swap it out when some axle weight is available. Electronics are still underwhelming me so I’m going to swap those out next. It sure is, holler if you do Bill Hey no problem, glad you found something useful in here and thanks for the read |
11-07-2019, 07:25 PM | #77 | |
I wanna be Dave Join Date: Sep 2019 Location: US
I realize, as many have pointed out in the various Capra threads, that the AR44 axles are narrower (by slightly more than an inch) than the stock Capra axles...but, the AR44 axles w/ portals is just under 1/2" wider than the stock SCX10 axles. Add wider hexes, and you're almost to the same width as the Capra axles. The way I see it, this setup would lower the COG...plus, adding the SSD portal weights increases the front weight, without increasing rotating mass. Thoughts? ~ More peace, love, laughter & kindness would make the world a MUCH better place | |
11-08-2019, 03:18 AM | #78 |
Update on the Over drive gears. I installed and tested the Boom racing keyed ar44 over drive gear and locker (Asiatees). It fit perfect in place of the stock gear and locker of the Capra. There are shims provided with the gears, but did not add any. Everything rotate smoothly. Just a FYI if anybody looks for Over drive gears. Now will watch the new video of Topher. |
11-15-2019, 11:53 PM | #79 | ||
After kicking around the idea of going brushless, and talking with a few of you here about brushed motors, I decided to go for upgrading from the reedy Radeon 2 five slot to a Holmes hobbies crawlmaster expert 16t. Got it installed tonight and am quite happy after a quick living room test. My biggest complaint about the reedy was the drag brake and secondarily the torque wasn’t what I was used to. Looking forward to trying it out on some rocks and seeing the improvement. Quote:
11-16-2019, 01:02 AM | #80 | |
topher builds a Capra - Similar Threads | ||||
Axial Capra | JatoTheRipper | Axial Capra | 284 | 06-03-2021 07:47 AM |
topher builds a TRX10.2 | Topher Builds | Traxxas TRX-4 | 60 | 01-05-2021 07:59 PM |
Bomber or Capra | macman809 | Axial RR10 Bomber | 54 | 02-28-2020 03:00 PM |
Capra forum? | Topher Builds | Comments, Suggestions, and Help | 14 | 01-22-2020 10:54 AM |
topher goes Full Sendero | Topher Builds | Element RC 1/10 Enduro Trail Truck Sendero | 79 | 12-20-2019 11:45 AM |
