Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Capra
Thread: Siggy's Capra 1.9 Unlimited Trail Buggy
Old 10-06-2019, 11:12 AM   #21
Default Re: Siggy's Capra 1.9 Unlimited Trail Buggy
Originally Posted by Siggy View Post
Are those measurements from hex to hex?
We need a front servo mount on the axle. Have no idea make if the one Vanquish has for their F9 SCX-II will also work on the F9 Portal Axles.
My understanding is that the VP SOA mount is compatible with all F9-based VP axles, portals included.
elRayRay is offline   Reply With Quote
Old 10-06-2019, 12:21 PM   #22
Siggy's Avatar
Axial Capra Upper/Lower Link Metal Rod-End won't mount on the Vanquish Portal Axles. If you can, Please let us know how. Thanks!
Siggy is offline   Reply With Quote
Old 10-06-2019, 12:37 PM   #23
Siggy's Avatar
Quick DiY Mod that Works!
Yes we manage to Succesfully Relocate Top Quality Smart 3S 2200mAh 100C/200C Burst and a VANT 2S 4600mAh 100C/200Burst under the Driver Cockpit.
And we need Driver/Co-Driver & Access to Battery & ESC Power Switch, Right?
Cut into half as shown on last Picture.
Then we can Secure with the 2 screws on the Co-Pilot side, Permanently. And either use screw or Double side/Velcro om the Battery Pilot side.
Oh yeah, easy to take out Cockpit for cleaning or Motor ESC Maintenance via the Window. Cheers!
Old 10-06-2019, 01:16 PM   #24
Siggy's Avatar
With DiY Mod of the Pilot Cockpit for Quick Access to Battery Replacement and ESC Power Switch. Gain Easy Way to take out Driver Cockpit via the Window.
Old 10-06-2019, 09:54 PM   #25
Siggy's Avatar
Now the Rerun XR10 Pro V4 160A + Xerun V10 GTR 17.5T Sensored Brushless Combo. Got Good Drag Brake and Speed on 3S, as well.
Thinking, 7T Cobalt Puller and FXR-PRO on 3S for the Ultimate in Low Speed TORQUE and Drag Brake.
Old 10-07-2019, 08:54 AM   #26
Siggy's Avatar
Old 10-07-2019, 10:54 AM   #27
Half way there to a 3D interior......
odomandr is offline   Reply With Quote
Old 10-07-2019, 11:09 AM   #28
Siggy's Avatar
NICE!
And if it will be with micro Realistic Lighting Speedometers/Guages, Moving Drivers and Steering Wheel, Shifting Gears, (Got a larger scale that's got all of these working function)-- that would be Nobel Prize Worthu in World of Scale Rigs.
Old 10-07-2019, 11:17 AM   #29
NICE!
I meant you.... just trim out that other guy, build a new floor and add wraith seats....
Old 10-07-2019, 11:48 AM   #30
Siggy's Avatar
I'm very happy with the Kit Cockpit. And just wanted to make sure my 3S 2200 and 2s 4600 & ESC fits Perfect -- as there is not enough room given the larger footprint under the hood. I needed access for both Lipo pack and power switch - that's why the mod.
Old 10-07-2019, 02:32 PM   #31
Siggy, so with the mods you've done... the battery is held in place by the interior? Looks really good, something I may well do myself TBH...
Old n ratty is offline   Reply With Quote
Old 10-07-2019, 03:55 PM   #32
Siggy's Avatar
Yes, if your Going for a the SpeKtrum Smart 3S 2200mAh 100C/200C Burst. I did not use any Velcro or Straps. I just shove-it in-place.
Seriously and the pack Fits and stay Secure. Does not bind the servo horn of the DiG. Yes I have the dig connected.
Oh yeah Bttery will not fit on the Co-Pilot side, in-case you are Wondering. Then I powered LEDs and 2 Servo direct via RX. Took out Red wire of the ESC. 2S ThunderPower 4000mAh RX Pack under the Hood Battery Compartment with on/off switch.
Ready to Rocks?!
Old 10-07-2019, 04:06 PM   #33
Siggy's Avatar
Full Articulation/Zero Bind on Steering Servo
2S 4000mAh RX Pack to Power Servo and LED's Direct
*Careful not to Burn DiG mini servo as these it is NOT a High Voltage Servo
Old 10-07-2019, 04:14 PM   #34
Siggy I'm a bit confused here. I put revo ends on the Capra links and bolted them up fine. I think White Trash also said the Capra hollow balls fit between revo ends and the new Capra ends. Were you using plastic rod ends or some aftermarket metal rod ends?
Sneetches is offline   Reply With Quote
Old 10-07-2019, 05:54 PM   #35
Siggy's Avatar
Are you confirming that all we need are the following:
1. CURRIE PORTAL F9 SCX10-II REAR AXLE - 199
2. CURRIE PORTAL F9 SCX10-II FRONT AXLE - 299
3. 16 Traxxas Large Rod Ends w/ Hollow Balls 12 pcs For Revo #5347 - 18
4. SCX10-II CURRIE F9 SERVO MOUNT 34.99
5. CURRIE/SCX 8 DEGREE TITANIUM TIE ROD/DRAG LINK 21.99
Then all we need is to do is an Easy & Quick Swap?
Old 10-08-2019, 10:13 PM   #36
Man, narrower axles and this stance would be a killer scale buggy. What length shocks do you think are needed to accomplish that ride height? 60mm?
generalee7 is offline   Reply With Quote
Old 10-09-2019, 08:11 AM   #37
Siggy's Avatar
Old 10-09-2019, 09:01 AM   #38
I would start with a 70mm shock...
1beatjeep is offline   Reply With Quote
Old 10-09-2019, 09:19 AM   #39
Siggy's Avatar
Old 10-09-2019, 11:52 AM   #40
Siggy's Avatar
Narrow vs Wide. Go Anywhere I can Fit vs Go Wreck-less Faster
Go 760, 70, 80, or 90. -- Try-out ALL you Got and Go have FUN! Kit Shocks Works, Internal Springs -- some say Slammed & Sexy.
Siggy's Capra 1.9 Unlimited Trail Buggy - Similar Threads
💥IN STOCK NOW💥 NEW Axial Racing Capra 1.9 Unlimited Trail Buggy Builders Kit! RPP Hobby RPP Hobby 0 09-27-2019 09:29 AM
PRE-ORDER NOW the NEW Axial Racing Capra 1.9 Unlimited Trail Buggy Builders Kit! RPP Hobby RPP Hobby 0 09-12-2019 10:43 AM
Class-3 W.E. Rock Unlimited Buggy build kona_joe 2.2 Scale Rigs 12 12-06-2015 09:05 PM
Siggy's RC4WD Trail Finder 2 Siggy RC4WD Trail Finder 2 21 02-21-2012 10:51 AM
