11-21-2019, 11:19 PM | #141 |
Quarry Creeper Join Date: May 2019 Location: North Highlands
| Re: Siggy's Capra 1.9 Unlimited Trail Buggy |
11-22-2019, 01:05 AM | #142 |
RCC Addict Join Date: Apr 2008 Location: Singapore
11-22-2019, 01:25 PM | #143 |
11-24-2019, 04:53 AM | #144 |
AWESOME Pictures by Massimo Bonvini shared at Axial Capra FB Page Thanks for your Interest and Support! Last edited by Siggy; 11-24-2019 at 04:56 AM. |
11-24-2019, 05:31 AM | #145 |
Very happy with the quality and fit. Bearings are snug without being tight. Perfect. |
11-24-2019, 07:26 AM | #146 |
11-26-2019, 01:27 AM | #147 |
Waiting on my Brass Portal Cover, 9T Motor Pinion, a set of SSD 2.2 Rock Racer Beadlocks and PitBull to just TRY. Thanks for your Patience snd Interest |
11-26-2019, 01:32 PM | #148 |
Rock Crawler Join Date: Mar 2012 Location: UK
You need a 32dp pinion?
11-26-2019, 01:52 PM | #149 | |
I wanna be Dave Join Date: Sep 2019 Location: US
| Re: Siggy's Capra 1.9 Unlimited Trail Buggy Quote:
~ More peace, love, laughter & kindness would make the world a MUCH better place | |
11-26-2019, 02:07 PM | #150 |
My Bad. 32 Pitch Confirm not 48Pitch. Sorry. I got Fooled. |
11-26-2019, 02:10 PM | #151 |
11-26-2019, 02:11 PM | #152 |
11-27-2019, 01:54 AM | #153 |
Quickly Sorted things-out. TAKE 2 Ordered online 9T 32Pitch by Robinsons Racing to TRY 1st hand for fit and Test Performance with the Vitavon Transmission with Dig. Will Update soon as I get it. The Vitavon Transmission is designed to give Driers the opportunity to select from 9T - 14T 32 Pitch. A Great Fine-Tune especially for Rock Crawling with Brushless Motor Combo and/or 2.2 Tires. With my 17.5Turn Sensored Motor on 3S, I would like to check if a 32 Pitch - 9 Tooth will WORK better than the kit supplied 14T. YES or No, in terms of Low End Torque, Top End Speed, for 1.9 and 2.2 Tires, PLUS Temp of Motor, ESC, and Battery -- that's the Plan. AGAIN, Sincerest Apologies for the Bad Stir in my earlier post. Thanks for your Patience. To confirm, 32 Pitch 9T-14 TMotor Pinion NOT 48 for the Axial Capra. Cheer! Last edited by Siggy; 11-27-2019 at 02:22 AM. |
11-27-2019, 07:48 AM | #154 |
I am curious how the 9T fits, and works, as I'd like to hear down further (currently running an 11T). Although I haven't yet received the Vitavon transmission housing, it should help cool the motor (being aluminum, it'll sorta-kinda act like a heatsink, pulling heat from the motor), I have done temp readings on my goat, inside a heated house. I'm currently running an 11T pinion, on a Castle"Slate" 2080kV, with a Mamba X, and 3S pack. I placed the Capra on a CI block, and ran the motor full-throttle for over 5 minutes...and, the hottest the motor ever got was slightly over 80°F. While the motor you're using is turning faster, thus generating more heat, with the cooling effect of the Vitavon housing, I'll estimate that your temp readings probably won't exceed 120-130°F, which is well below the "danger zone". Considering you'll be using that 9T, temps should be even lower. Will be awaiting your results. ~ More peace, love, laughter & kindness would make the world a MUCH better place |
11-27-2019, 06:34 PM | #155 |
11-27-2019, 06:53 PM | #156 | |
11-28-2019, 03:30 AM | #157 | |
Very much like all the Rest of the Favourites in the Fleet . . . an Unending Work-in-Progress. ENJOY! | |
11-28-2019, 03:53 AM | #158 |
2.2 on the Capra is NOT a Favourite of All. BUT many @ FB did indicate the Love it! Well, I tried with the 2.2 Vanquish Methods and the 2.2 SSD Rock Racer, and with the VITAVON Weighted Brass Portal Cover -- installation was easy and Totally bind free - no need for Spacers. And FWIW, we get Maximum steering (Left and Right) -- ZERO Bind of wheels on the lower link, as well. ENJOY EQUIOMENT Installed: 2.2 SSD Rock Racer 2.2 PIT Bull Pock Beast II Vitavon Brass portal Cover for the Front NO Spacer or Any Modifications Required to WORK Flawless. Go Ahead, Go 2.2 if that's what your Heart Honestly Desires! |
11-28-2019, 04:09 AM | #159 |
Rock Solid Portal Axles Maybe TRU SCALE Perfect for a 1.9 Capra Competition Rock Racer. Yes Narrower Track Width mid get them 2.2 Wheels to Bind on Lower Links. ANYWAYS, No Doubt many like these Quality HD Aluminium Scale Housing, HD Chromoly Internal Gears and Shaft and Front Portal Axle Overdrive Gear (option). SURE, I'm ALL-In for things that Work GREAT . Oh yeah, Please Tell US Why WE should or Should NOT?! Last edited by Siggy; 11-28-2019 at 04:14 AM. |
11-28-2019, 02:50 PM | #160 |
Siggy's Capra 1.9 Unlimited Trail Buggy - Similar Threads | ||||
💥IN STOCK NOW💥 NEW Axial Racing Capra 1.9 Unlimited Trail Buggy Builders Kit! | RPP Hobby | RPP Hobby | 0 | 09-27-2019 09:29 AM |
PRE-ORDER NOW the NEW Axial Racing Capra 1.9 Unlimited Trail Buggy Builders Kit! | RPP Hobby | RPP Hobby | 0 | 09-12-2019 10:43 AM |
Class-3 W.E. Rock Unlimited Buggy build | kona_joe | 2.2 Scale Rigs | 12 | 12-06-2015 09:05 PM |
Siggy's RC4WD Trail Finder 2 | Siggy | RC4WD Trail Finder 2 | 21 | 02-21-2012 10:51 AM |
