10-24-2019, 08:09 PM | #61 | |
I wanna be Dave Join Date: Sep 2019 Location: US
| Re: El Chivo Quote:
Sent from my SM-T830 using Tapatalk | |
10-24-2019, 10:16 PM | #62 |
| Re: El Chivo
And then this happened... 3d printed weight hangers vmgontherocks gave me over a year ago and some hanger brackets made from dividers for tackle boxes. |
10-24-2019, 10:37 PM | #63 |
| Re: El Chivo
Stop being such a tease and show us the goods!🤣
10-24-2019, 10:59 PM | #64 |
| Re: El Chivo
My ghettoness isn't really worthy of showing off but whatever. These put me back up to 5.05 lbs but in ok with it. |
10-25-2019, 12:20 AM | #65 |
Pebble Pounder Join Date: Oct 2019 Location: Kula
| Re: El Chivo |
10-25-2019, 07:23 AM | #66 |
| Re: El Chivo |
10-25-2019, 09:15 AM | #67 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
| Re: El Chivo |
10-25-2019, 09:18 AM | #68 |
| Re: El Chivo
I don't have the file for these holders. They are 3/8 x 7/16" tungsten pine car slugs. Dluxfab.com has by far the best price on them. |
10-25-2019, 10:19 AM | #69 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
| Re: El Chivo
What would you do with 8 slugs on each side?
10-25-2019, 10:39 AM | #70 | |
| Re: El Chivo Quote:
Lol yup sneetches is right. I hope who ever did the print used ABS filament. Regular PLA tends to break down and warp when exposed to UV. Sent from my iPad using Tapatalk Pro | |
10-25-2019, 12:04 PM | #71 |
| Re: El Chivo |
10-25-2019, 01:16 PM | #72 |
| Re: El Chivo
You feeling ok today? You dont look so well. You should tell your boss you need to leave early. |
10-25-2019, 02:02 PM | #73 |
| Re: El Chivo |
10-25-2019, 03:02 PM | #74 |
| Re: El Chivo
Since you're on a diet, cut out some of the excess angled pieces at the top of the cage and maybe the rear angled downtubes. |
10-25-2019, 03:17 PM | #75 |
| Re: El Chivo |
10-25-2019, 06:00 PM | #76 |
| Re: El Chivo |
10-25-2019, 06:56 PM | #77 |
| Re: El Chivo |
10-25-2019, 10:36 PM | #78 |
| Re: El Chivo
Just got home. Let the games begin! Casey you should do them in delrin for shizzle. Light weight with only low hanging would be groovy too. |
10-25-2019, 11:35 PM | #79 |
| Re: El Chivo
So as it turns out the diagonal measurement of the capra portal cover is half a RCH larger than 1" so the printed tungsten hangers happened to work out and fit inside my wheels. The Krazed covers fit nicely as expected and they center off the 4 bolt bosses. The covers have recesses around each bolt to do the job. This does require the raised portion between the bolt holes be cut off with a razor blade but it's easy and quick so no drama. Bob, as expected the bolt pattern on the hangers and diameter is spot on so dlux dice weights drop right on too. If I'm feeling really froggy I can bolt on 7.75 oz per knuckle off of a comp rig. Last edited by WHITE-TRASH; 10-25-2019 at 11:38 PM. |
10-26-2019, 05:38 AM | #80 | |
| Re: El Chivo Quote:
Looks like you got plenty of options now for weight too. I was curious if delrin hangers would be a better option. Last edited by Robbob; 10-26-2019 at 01:02 PM. | |
