10-26-2019, 08:33 AM | #81 |
| Re: El Chivo
Yea it just kinda works out. Today is the warmest day for the next week so I'll get the out and test how she does now with a bit of weight in all the right places.
10-26-2019, 08:54 AM | #82 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
| Re: El Chivo
Nice build thread! Thank you for your continued use of CI 6 Bolt Wheels It will be interesting to see if the Capra inspires more "scale" or "comp" style builds & competitions. I'm hoping for more of the comp style myself.
10-26-2019, 09:07 AM | #83 | |
| Re: El Chivo Quote:
I don't think there is a wrong use for the capra. It's the best bang for the buck to get into class 3 sorcca or sportsman comp. I'll be picking up a second one just to build a sporty for next year. A couple of the local guys saw me posting about this rig and picked them up for class 3, looks like I'll actually have to put in effort to win the points series next year. | |
10-27-2019, 03:04 PM | #84 |
| Re: El Chivo
What a difference a few oz per knuckle makes! She was ripping lines it had no business being on today. |
10-27-2019, 05:25 PM | #85 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Re: El Chivo
Why do you like plastic glue on Wheels versus beadlocks of any sort? Just curious Sent from my LM-G710VM using Tapatalk |
10-27-2019, 05:37 PM | #86 |
| Re: El Chivo
Light weight. Maximum clearance so there is never any issue fitting any knuckle I happen to run. Cheap. Slw compatible. Never any headache with proline beads. Because 1.9's suck. Because beadlocks suck. |
10-27-2019, 05:42 PM | #87 | |
| Re: El Chivo Quote:
Sent from my LM-G710VM using Tapatalk | |
10-27-2019, 05:48 PM | #88 |
| Re: El Chivo |
10-27-2019, 06:08 PM | #89 | |
I wanna be Dave Join Date: Sep 2019 Location: US
| Re: El Chivo Quote:
~ More peace, love, laughter & kindness would make the world a MUCH better place | |
10-27-2019, 06:15 PM | #90 | |
| Re: El Chivo Quote:
Sure but at the expense of rotational mass. If you're just crawling slowly it's fine but once you whack the throttle you're going to accelerate slower and slow down at a lower rate than if you were running a light weight setup. I run a lot of power and light parts with a decent amount of knuckle weight in all of my rigs and it just flat works for me. | |
10-27-2019, 06:18 PM | #91 | |
| Re: El Chivo Quote:
~ More peace, love, laughter & kindness would make the world a MUCH better place Last edited by Panther6834; 10-27-2019 at 06:22 PM. | |
10-27-2019, 06:25 PM | #92 |
| Re: El Chivo
Knuckle weights are coming very soon. I don't care much about looks, I want my junk to work. |
10-27-2019, 06:27 PM | #93 | |
| Re: El Chivo Quote:
The way I'm looking at it, the Capra (my first crawler) is about looks, performance, and capabilities (1/3 each). My second (RC4WD TF2-based) will be 65% looks, 25% capability, & 10% performance. The third (Vanquish VS4-10) will 40% performance, 40% capability, and 10% looks. Finally, the fourth (yes, I know, I originally said I'd only have 3,but I've reconsidered, for a total of 4) will be a "rock racer" (obviously, still undecided on what that one will be). ~ More peace, love, laughter & kindness would make the world a MUCH better place Last edited by Panther6834; 10-27-2019 at 06:41 PM. | |
10-27-2019, 06:29 PM | #94 |
| Re: El Chivo
Yean I agree that why I like CI 6 bolt wheels. They look good sitting and they look great as they perform better than a beadlock. |
11-01-2019, 11:39 AM | #95 |
| Re: El Chivo
Been burning up battery packs lately and decided I wanted a little more pep in its step. So I did the dosey doe with a few rigs and optimized them all. Capra got the 2700 holmes from the trx4, the class 3 toyzuki V3 got the old 2300 tekin from the capra and the 1900 tekin from the class 3 went in the trx4. So now they should all be a bit better over all. |
11-01-2019, 12:35 PM | #96 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
| Re: El Chivo
Looks like you've worn it in pretty well, whats your opinion on the Capra skid by itself?
11-01-2019, 12:36 PM | #97 |
Quarry Creeper Join Date: Nov 2015 Location: US
| Re: El Chivo
Rippin in the Capra cruising the toyzuki and puttin around in the trx4
11-01-2019, 01:01 PM | #98 | |
| Re: El Chivo Quote:
The TZ is 4s all the time and trx4 see 4s more often than not so it all works out. The capra has an 11 tooth pinion so a bit more pep isn't a bad thing. I'll gear up the trx4 if needed but it was a bit much in high gear due to the added gearing of the 2.2's it runs. | |
11-01-2019, 01:04 PM | #99 |
| Re: El Chivo |
11-01-2019, 01:18 PM | #100 | |
| Re: El Chivo Quote:
I'd like to see traxxas make their rod ends with more than a 10* bend so they can be used on more applications. They're fawking tough compared to the old revo ends. | |
