Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Capra
Thread: Stub nose Capra
Old 10-05-2019, 12:05 PM   #1
Default Stub nose Capra
I'm a lover of rock buggies, so as you could imagine the release of a decent 1.9 buggy was an exciting thought for me. Typically I build my rigs from scratch so this is one of the few rigs I put together from a box and left it alone (mostly). However I have my complaints as usual. While it's a very nice kit with superb parts and great quality the proportions of it have bugged me from the beginning. The axles are awesome but too wide for the body, stock it's much too tall, and finally the nose is unnecessarily too long from windshield to grill, I think the designer may be compensating for something (jk) so with a little trimming and a couple grub screws I took about 1/2 inch out of the front tube work, I am much happier with the results, as for the axles I will leave them be for now but someday some narrower axles might find themselves under this thing, the height I'm still working on, right now I'm using proline powerstrokes at 90mm but I still want to go shorter.
Rock solid is offline   Reply With Quote
Old 10-05-2019, 12:20 PM   #2
Default Re: Stub nose Capra
That does look better without the overbite! Kinda reminded me of Otto from the Simpsons before. How did you reattach it after the cut, really long screw in the bottom?
TheLetterJ is offline   Reply With Quote
Old 10-05-2019, 12:22 PM   #3
Does that snubbie affect the range of motion being an axle mounted servo? I do like how it looks. Mine is still in the box.
Brake Weight is offline   Reply With Quote
Old 10-05-2019, 12:40 PM   #4
The bottom tube work I just cut a half inch out then drilled down the center of the plastic tube, then reattached both pieces with a short 3mm grub screw like what you use in tie rod ends, the top section I just cut off the end then drilled a new hole down the center to attach the grill. The hood I cut off the end then shaped for new lines. The cross section under the hood I just attached it at the rear shock mount, There is no affect on the servo.
Old 10-05-2019, 01:32 PM   #5
Go Buckeyes!
B-MOW71's Avatar
I like the look of the stub nose. It fits good with the short stubby rear end. Great job!
I will keep this in mind for my future Capra!
B-MOW71 is offline   Reply With Quote
Old 10-05-2019, 01:38 PM   #6
Excellent. This will be done to mine straight away. Along with flat panels and maybe a rear panel to box it in like a true tub.
Old 10-05-2019, 03:48 PM   #7
sketchiness abounds...
durok's Avatar
Nice - really clean mod!
Goes a long way in changing the look.
durok is offline   Reply With Quote
Old 10-05-2019, 06:20 PM   #8
Slow is the new fast
smog's Avatar
It looks better snub, no question. Good eye.
smog is online now   Reply With Quote
Old 10-05-2019, 06:42 PM   #9
Nice idea and it looks clean, you could probably pass it for stock if you didn't tell us.
Sneetches is offline   Reply With Quote
Old 10-05-2019, 07:06 PM   #10
dezfan's Avatar
Snub nose.
Me like! 👍🏼
dezfan is offline   Reply With Quote
Old 10-05-2019, 07:53 PM   #11
Looks great!
soze is offline   Reply With Quote
Old 10-05-2019, 11:00 PM   #12
Moderator
JatoTheRipper's Avatar
Stock looks fine to me, but this looks great. Nice creativity on making it work with relative ease.
Old 10-12-2019, 09:44 AM   #13
Thanks fellas. I finally got my capra painted and finished. I'm definitely liking it more than I thought I would. Later today I'll test it on the rocks.
Old 10-12-2019, 10:46 AM   #14
I really like the stub-nose look of it...but, I think I'm going to leave that area alone for now. I'm already working on a minor mod to the front grill (headlights), and a major mod to the interior, so I just want to finish things up, and see how it runs...or crawls.
Panther6834 is offline   Reply With Quote
Old 10-12-2019, 09:04 PM   #15
Got a few shots on the rocks. Crawls really well, just some minor torque twist that needs taken care of.
Old 10-13-2019, 10:58 AM   #16
Shweet snub nose!!! Me like broski!
distinctive pd is offline   Reply With Quote
Old 10-14-2019, 10:20 AM   #17
Really liking the snub nose idea! Great job
twisted concept is offline   Reply With Quote
Old 10-15-2019, 01:54 AM   #18
You are loosing a beadlock bolt in the first picture!
Really nice mod, I like this stub nose look. care to share if you managed to keep the fast release front hood mounts? By the pics looks like that feature was lost
rockspider is offline   Reply With Quote
Old 10-15-2019, 06:39 PM   #19
I could have retained the quick release pin setup with simply making 2 more cuts and moving that section back, however I went for quick and simple and just used 2 screws down through the front cage work where the corners were gusseted.
Old 03-18-2020, 11:37 AM   #20
What did you do to latch the hood since you removed the latches?
01tj is offline   Reply With Quote
Stub nose Capra - Similar Threads
Axial Capra JatoTheRipper Axial Capra 284 06-03-2021 07:47 AM
topher builds a Capra Topher Builds Axial Capra 100 03-16-2020 08:03 AM
Bomber or Capra macman809 Axial RR10 Bomber 54 02-28-2020 03:00 PM
Capra forum? Topher Builds Comments, Suggestions, and Help 14 01-22-2020 10:54 AM
scania stub nose #128 SEMIJOE Non Crawler RC's 4 04-27-2010 06:31 AM
