Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Capra
Thread: Capra MODS
Old 10-06-2019, 04:15 PM   #1
Default Capra MODS
Any good Mods our there for lower CG and better performance?
BEAU is offline   Reply With Quote
Old 10-08-2019, 04:19 PM   #2
Default Re: Capra MODS
change the shocks to shorter shocks, put some limiter on the inside (fule tubing, pen spring) or run full droop.
Broc's RC is offline   Reply With Quote
Old 10-08-2019, 04:41 PM   #3
Several have mentioned switching to 90mm shocks, which puts the lower links parallel to the ground. You can always add wheel weights, which would lower the CoG.
Panther6834 is offline   Reply With Quote
Old 10-08-2019, 04:52 PM   #4
My links are parallel to the ground just by using the softer springs, no limiters. I actually really like the stock shocks, they did a good job on these (other than the springs rubbing a tad).
punkindrublik is offline   Reply With Quote
Old 10-10-2019, 10:25 PM   #5
Is a full droop, no spring and heavy weight oil?
Old 10-11-2019, 05:01 AM   #6
Same for me.
GA Dawg is offline   Reply With Quote
Old 10-12-2019, 11:07 AM   #7
Axial did such a nice job molding their logo into the grill.
It's such a "shame" I had to (carefully) cut it out.
Capra MODS - Similar Threads
Axial Capra JatoTheRipper Axial Capra 284 06-03-2021 07:47 AM
Stub nose Capra Rock solid Axial Capra 21 05-09-2020 07:54 AM
topher builds a Capra Topher Builds Axial Capra 100 03-16-2020 08:03 AM
Bomber or Capra macman809 Axial RR10 Bomber 54 02-28-2020 03:00 PM
Capra forum? Topher Builds Comments, Suggestions, and Help 14 01-22-2020 10:54 AM
