11-02-2019, 03:46 PM | #61 |
RCC Addict Join Date: Dec 2014 Location: So Cal
| Re: What’d you do with your goat today?
It could be the space shuttle, a buddy of mine was heavily involved with it. Picture a Ford I beam 4x4 front end mated with a Razor's rear suspension..... What is the max width and wb to comp it if they would let it in, 4 wheel steer?
11-02-2019, 04:27 PM | #62 |
Class 3 allows anything for wheelbase or width but the body cant be more than 1.25" from the inside sidewalls. Wheelbase is up to you.
11-02-2019, 05:42 PM | #63 |
So I could build a wide body per the dimension criteria (not the cage, or add nerf bars to the chassis), run AR60s and be legit?
11-02-2019, 07:43 PM | #64 |
Quarry Creeper Join Date: Nov 2015 Location: US
There is a gate width minimum too that you could exceed if you went stupid
11-03-2019, 03:21 PM | #65 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
Short run with a few other goats, switched to 90mm shocks for this one and didn’t see much of an improvement, may switch back to the stock shocks after one more run. Impatiently waiting for some brass portal boxes to help plant the front. |
11-03-2019, 04:31 PM | #66 | |
Quarry Creeper Join Date: May 2019 Location: North Highlands
| Re: What’d you do with your goat today? Quote:
UPDATE: Called Axial today (aka Horizon) and they have a new housing on the way to me au gratis. So that's $10 I didn't have to spend. Kudos. Last edited by punkindrublik; 11-04-2019 at 02:47 PM. | |
11-03-2019, 06:02 PM | #67 |
Ah man that crack followed the chub right up. Tough break. Was it a bad fall? |
11-03-2019, 06:14 PM | #68 |
| Re: What’d you do with your goat today? |
11-03-2019, 06:19 PM | #69 | |
At $10 a pop, I may pick up a spare front housing to have on hand for a just in case. https://www.rpphobby.com/product_p/axi232004.htm | |
11-03-2019, 06:32 PM | #70 |
Maybe drizzle some 2-part epoxy where that fracture occurred. Maybe lay a little fiber in it also. Or wait on the aftermarket to catch up.
11-03-2019, 06:43 PM | #71 | |
I wanna be Dave Join Date: Sep 2019 Location: US
~ More peace, love, laughter & kindness would make the world a MUCH better place | |
11-04-2019, 09:48 AM | #72 |
Spent yesterday painting this fuel cell and a couple others. Hit the straps and bolts with a chrome pen this morning before work and then put it back in to the back of the cage. Need to let the lid cure another day before it's screwed on as the paint seems a bit fresh still Sent from my Pixel 2 XL using Tapatalk |
11-04-2019, 02:46 PM | #73 | |
Called Axial today (aka Horizon) and they have a new housing on the way to me au gratis. So that's $10 I didn't have to spend. Kudos. | |
11-04-2019, 02:56 PM | #74 | |
11-04-2019, 03:04 PM | #75 |
Made a interior side panel to stick my ESC and Rx to. I swapped motors and for the life of me couldn’t get the wires soldered to the new motor. Bought new solder and 2 kinds of flux. Snipped back at least an inch of motor lead each attempt and finally got some to stick this morning....with my original solder and flux. Uber cheap MG servo. Set it up in 5 minutes or less. But I didn’t realize my RadioLink 3ch is a knob and not a button. Found middle and set the horn for freewheel, set 4wd endpoint, and then locked endpoint. The servo bracket is so flimsy it is it’s own servo saver. LOL. |
11-04-2019, 03:09 PM | #76 |
Oh. I dug these out of a box of tires. Broke the old tire glue off and yanked the star cut foams. Stuffed them with some oversized foams for now and stuck them on these Revolvers. Love these wheels. Was considering another set of CI 1” wheels but will stick with these. Now to figure out what foam for a 4” carcass tire. |
11-04-2019, 03:36 PM | #77 |
Today, I finally put the "finishing touches" on the interior, applied the 'flat clear' to the top of the Lexan, applied the interior decals, started installing the replacement driver & navigator, and finished the replacement steering "wheel". Unfortunately, due to a visit from an Inquisitor, I'm unable to share photos (at this point in time) of the interior.....so photos of just the steering "wheel" will have to do. ~ More peace, love, laughter & kindness would make the world a MUCH better place |
11-07-2019, 02:41 PM | #78 |
THAT WAS FAST! Kudos Axial/Horizon |
11-07-2019, 04:03 PM | #79 |
Hit the trail for a couple hours today and saw this beauty!
11-07-2019, 05:48 PM | #80 |
What’d you do with your goat today? - Similar Threads | ||||
Goat 2s to 3s possible? | Hoyta | Electronics | 1 | 06-10-2015 09:40 PM |
Goat 2s help.... | msd44 | Electronics | 10 | 03-12-2012 08:02 AM |
Novak Goat Vs Novak Goat Ballistic?? | k_r_a_c_k_e_r | Electronics | 3 | 02-19-2010 07:53 PM |
new goat 3s | redking | Electronics | 2 | 09-02-2009 11:13 AM |
