![]() | #1 |
Newbie Join Date: Aug 2019 Location: Tracy
I would like to see how you wire your Capra
![]() | #2 |
#masterpiece #ocdasfawk #4SornoS
![]() | #3 |
I wanna be Dave ![]() Join Date: Apr 2010 Location: Oakridge
![]() | #4 |
![]() | #5 |
Quarry Creeper Join Date: May 2019 Location: North Highlands
About as clean as I could get it. The stray red wire is my unmounted switch... ![]() ![]() ![]() Last edited by punkindrublik; 10-12-2019 at 07:41 PM. |
![]() | #6 |
Newbie Join Date: Oct 2019 Location: Gulf Coast
I don't know about masterpiece but it works. ![]() ![]() ![]() ![]() |
![]() | #7 |
Quarry Creeper Join Date: Feb 2007 Location: Lleida
Why you run an external bec?
![]() | #8 |
Running 7.4V to the steering servo and have the micro dig servo at 6V through the esc's onboard bec.
![]() | #9 |
![]() | #10 |
Custom Carbon Fiber ![]() Join Date: Oct 2007 Location: Connecticut :(
![]() | #11 |
Rock Stacker ![]() Join Date: Oct 2013 Location: Ocala
Not perfect, but works.
![]() | #12 |
RCC Addict Join Date: Sep 2019 Location: US
It's not finished, but here's what I have so far: ![]() Headlight & servo wiring. The two 'tubes' that you see on the sides of the battery compartment contain the two antenna. I tried to glue the driver side tube in place, using CA glue, but it didn't hold, so need to come up with an alternate idea. ![]() Navigator side, where the Rx is installed. The red/black wire going straight up is the power switch, which can't be placed where it will be going...at least not yet. I also replaced the stock senator wire with a much shorter one (approx 1/3 the length), as the motor & ESC are so close to each other. ![]() Driver side, where the two CPS-1 units, for remotely controlling the headlights, and lightbar, are installed on the electronics tray. As you can see, I had no choice but to "give in", and installed the ESC in front of the fuel cell. I used a pull-tie (I usually use these in building computers) to "bind" the excess lighting working together, and to hold it against the inside of the cage (driver's 'door'). ![]() ![]() ~ More peace, love, laughter & kindness would make the world a MUCH better place Last edited by Panther6834; 10-25-2019 at 01:46 PM. |
![]() | #13 |
Pebble Pounder Join Date: Oct 2019 Location: Kula
| ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk Pro |
![]() | #14 |
I wanna be Dave ![]() Join Date: Oct 2012 Location: Medina
![]() | #15 |
Not complete yet, but this is where I started . ![]() ![]() Sent from my moto z4 using Tapatalk |
![]() | #16 |
Pebble Pounder ![]() Join Date: Mar 2012 Location: Fort Collins
I figured it out.
![]() | #17 |
| ![]() ![]() ![]() ![]() ![]() I figured I would add some of my wiring photos. |
![]() | #18 | |
Pebble Pounder Join Date: Oct 2006 Location: Knoxville
| ![]() Quote: | |
![]() | #19 | |
| ![]() Quote:
Yep, did many test fits before the location of everything was finalized, fits nicely, may goal was to get the Mamba down low up front and counter some motor weight. It took a few weeks just working on it a few times a week after work, but I am happy to start wrapping up the build now that all of the wiring is finished. | |
![]() | #20 | |
Go Buckeyes! ![]() Join Date: Jun 2017 Location: Mid-Ohio
| ![]() Quote:
![]() I like the carbon fiber inner panels for mounting the electronics. Great idea! | |
2s wiring | jimjam | Electronics | 5 | 11-23-2010 04:13 PM |
PLease Help with Wiring!!!!! | drewswwn06@yaho | Electronics | 4 | 02-02-2008 05:07 PM |
