Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Capra
Thread: New Capra build, need KV opinions
Old 10-14-2019, 02:10 PM   #1
Low King
Default New Capra build, need KV opinions
Hello all, I am going to the hobby shop in about 1/2 hr to pick up my Capra and I have a few questions from peeps that have built them already. I was thinking of a HH PP just don't know what kV rating would be best, for that matter is there a reason to go with a stubby? I want to keep 5mm pinion shaft.
I am going to use a CC Mamba X I already have and probably either Reefs 444 or Hitec D950TW (so I can program center and end points) also going with Vanquish 105's 225 hubs and I will be adding more light and a winch.
Also I haven't used Axial shocks in years are the stock one pretty good, if not I was thinking of grabbing a set of Kronik 100mm's. Thanks for your help, I will be mostly just having fun on rock piles make try a competition if I can find one. Ed
edjo69 is offline   Reply With Quote
Old 10-14-2019, 03:21 PM   #2
Default Re: New Capra build, need KV opinions
I have a 2700kv stubby in mine and could definitely afford to lose some top end, running 3s and an 11t pinion. Plenty of power to break the clutch loose, and it lets me get away with running the smaller Mamba Micro X esc, so no real downside to the stubby for me. A 2200kv, or less if you intend to run 4s, may be a better match for the Capra.
TheLetterJ is offline   Reply With Quote
Old 10-14-2019, 03:40 PM   #3
Low King
Not going to be running 4s, 3s will be the limit, sounds like maybe with my ESC choice going with the 2200 might be a way to go to keep the good grunt and not having a bunch of overhead hi-end that wont get used? I sent JH an email asking him his thoughts maybe he will pop in to add to the opinions to ponder. Thank you TLJ!
Old 10-14-2019, 07:41 PM   #4
Low King
I decide after watching a few YT vids that I will start with a 2700kV Puller Pro and go from there, ordered the method 105's and Hyrax orange dots, the axial servo saver parts tree so I can use a different micro servo, its going to be Spektrum 5ch, 1 aux for the DIG, 1 aux for lighting and 1 aux for rock lights all switched from TX. I went with a Hitec D-950TW for steering and either a D-85MG or a MKS-HV69 for the DIG control. This will be my first full blown crawler in over 6 years and that one was a Wraith! Very much looking forward to starting in on it!! need to find those comparison pictures to actual rigs, I like leaning scale when I can. Thanks, E
Old 10-16-2019, 07:20 PM   #5
I finally got mine up and running today. I’m using a Mamba X and a 3500kv Puller Pro on a Reedy 3S. WAAAYYYY too much motor. It’ll pull wheelies in my driveway from a roll!!! I would get a 2700Kv, maybe even a 2100kv depending on battery. I would also recommend getting a stubby motor due to space.
Lashlee is offline   Reply With Quote
Old 10-16-2019, 07:35 PM   #6
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
2200 stubby would be my first recommendation. We are moving the shop capra from a 1800 revolver to a 2200 stubby. Well, did it already today. Just right on 3s with a 10t pinion IMO.
JohnRobHolmes is offline   Reply With Quote
Old 10-16-2019, 09:03 PM   #7
Low King
Yeah, at the last minute Jeff replied to my contact question on your site and I changed it to a 2200 PP, he didn't mention the stubby, for that matter I didn't either, any downside to the regular PP over the Stubby?
Old 10-16-2019, 09:08 PM   #8
thats right, we did use a standard. It needs a bit of shaving the link mount to fit, the stubby doesn't. standard has a lot better drag brake.
Old 10-16-2019, 09:45 PM   #9
WHITE-TRASH's Avatar
I have a 2300 roc in my capra and its solid on 3s with a 11 tooth pinion. Lots of fun on 4s too.
WHITE-TRASH is offline   Reply With Quote
Old 10-17-2019, 12:48 AM   #10
I've been looking at this motor for an all Tekin install as well. Did you need to do any trimming to make it fit?
KulaHI is offline   Reply With Quote
Old 10-17-2019, 05:19 AM   #11
Just the tiniest bit of shaving on the inside edge of the rear upper link mount..
Old 10-17-2019, 10:24 AM   #12
Good to know thanks!
Sent from my iPhone using Tapatalk Pro
Old 10-19-2019, 01:18 AM   #13
Guys my searches are coming up empty. Any recommendations for a waterproof HV micro (dig) servo?
Old 10-19-2019, 02:19 AM   #14
Traxxas 2065x fits.
Old 10-19-2019, 02:43 AM   #15
Traxxas 2065x fits.
it's 6v only though right? Looking for something that will work at 7.4v. Ideally I'd like to run both dig and steering servo from the ESC's BEC @7.4v
Old 10-19-2019, 06:22 AM   #16
Unofficially they are good to 7.4. My trx4 runs 7.4 and has for about a year without skipping a beat.
Old 10-19-2019, 07:15 AM   #17
The PowerHD TR-4, made to replace the 2065, is good for 7.4v.
Sent from my LG-H870DS using Tapatalk
bbrigg is offline   Reply With Quote
Old 10-19-2019, 08:37 AM   #18
Low King
MKS, Reef both make one that will handle 7.4v
Old 10-19-2019, 10:06 AM   #19
Why not install the Holmes Receiver Bypass, along with an external BEC? That way, you can use the external BEC (such at the CC BEC 2.0, which is rated up to 15A) to power the steering servo at 7.4V, plus use the ESC's internal BEC, set at 6V, to power everything else (DIG servo, LEDs, etc).
Panther6834 is offline   Reply With Quote
Old 10-19-2019, 11:13 AM   #20
Ah cool! Canít beat the price either.
Thanks guys Iíll give those a look as well.
Yeah thought of that but I really was looking to try and keep the wiring simple, no leds. Used to build and fly drones before they regulated the fun out of it. Even the TBS Discovery with a PCB frame could turn into a tangle of wires if you werenít careful. I say this now but who knows what might happen later, I just realized I got a lot of FPV stuff collecting dust.
New Capra build, need KV opinions - Similar Threads
Capra America: A Super Build by SVT svt923 Axial Capra 60 10-24-2019 01:12 PM
Opinions on a new motor for my build. GTSLOW Electronics 5 03-20-2017 09:32 AM
need some opinions for my new build... jared86 General Scale Talk 0 12-26-2014 10:26 PM
Need opinions on new build school boy Axial SCX-10 4 02-15-2014 12:08 PM
your opinions on my build 4goodbuys2 1.9 Scale Rigs 5 04-12-2010 05:18 AM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
