What did you change on your Capra? Why? Being that this rig is the latest and greatest, what did you change and why did you find it necessary to do so? Maybe this will morph more into a tuning thread than a beauty pageant, but for those who have altered, perhaps to help those who are undecided on pulling the trigger and are sitting on the fence, does it require a lot of upgrades? For me, being an aluminum body fab guy, the lexan panels would be the first to go, mainly because too many different body styles are incorporated into the limited real estate. Cosmetic, yes, but so are wheels. So what have you done? Geometry? Shocks? ??????? |
Re: What did you change on your Capra? Why? 1 Attachment(s) Replaced the front upper links with some titanium links I had on hand that were 10mm shorter for a better castor angle. The upper links are short on this rig anyway but when lowered the pinion angles go to hell and takes the castor with it I also replaced the shocks with 2661 big bore traxxas with mini t springs. Lower and more tuning options since I don't have 12mm traxxas or axial springs on hand like I do mini t. Modified the steering stops and the c hubs for more steering angle. This required putting a couple bends in the tie rod too. I made my own body panels too. Cheap and easily replaced when they get too mangled. I'm running 2.2's on it too. Always 2.2 wheels but also tires at the moment. Still haven't had it out to see how I like it in this incarnation yet. |
Re: What did you change on your Capra? Why? Ryan did you run it with the stock shocks before putting the 90mm on there? Curious to hear some first hand comparison experience, however most people I’ve seen run 90mm shocks did it during the initial build. |
Re: What did you change on your Capra? Why? Nope, I never even put them together once I saw the ride height they provide. |
Re: What did you change on your Capra? Why? I shortened my shocks to 90mm and I’m running the stock Enduro springs with 40wt oil. I wanted lower the CG, I usually run my rigs with more droop travel, and the 40wt oil to slow down the drop out a bit. I may go a bit heavier after I get some wheel time. |
Re: What did you change on your Capra? Why? My Capra has front over drive gears, ssd brass wheel hubs up front, and 90mm springs (stock shocks). Still plenty of room for improvement but this platform is such a good base that even those few mods makes for a fun and capable rig. <iframe width="560" height="315" src="https://www.youtube.com/embed/uWuhQ63mRII" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> |
Re: What did you change on your Capra? Why? Good climb at the end. Dare I ask how deep $$$$ you guys are when done? Typical complete build cost? |
Re: What did you change on your Capra? Why? Most of the stuff on my capra came from what I had around, but if I had bought it all new for this build I’d be in around $700-$750 excluding the transmitter. |
Re: What did you change on your Capra? Why? Wow that front end is really glued down on this climbs! Mind saying what gearing you’re using up front? Sent from my iPad using Tapatalk Pro |
Re: What did you change on your Capra? Why? Quote:
I've not done the mod myself but I've gotten good results bending small pieces of metal with a vise finger brake. https://www.google.com/search?client...w=1584&bih=859 |
Thanks Topher! That seems to be a worthwhile mod I might attempt at some point!"thumbsup" |
A vice and a mallet will do it. No need to go crazy it's just stainless after all so it'll bend easily. |
Re: What did you change on your Capra? Why? I cut the area out where the end of the battery goes. Not buying new batteries over 5mm. |
Thanks! I'll get it bent tomorrow after I hit the rocks in the morning. |
Re: What did you change on your Capra? Why? i swapped some ssd pinions and shaft to produce legit overdrive in the capra frontaxle https://www.rockcrawler.de/wcf/attac...20-204112-jpg/ |
Sent from my SM-G965U1 using Tapatalk |
Re: What did you change on your Capra? Why? I was wondering since the total reduction is pretty hi stock, why not under-drive the rear axle? I would like to do this to mine but I really don't know how to go about doing it, it looks like from the picture above doing it in the portal box would be the simplest and more robust way to do it, does anyone have any ideas they might throw my way?? |
Re: What did you change on your Capra? Why? So what is the general synopsis of the upper shock mounting locations? I am staring at a blank cage and see the fronts mess up the battery size area. Anyone "feeling me" with this? Rears jack up the body lines....... |
