Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Capra
Thread: Jeeper mods a Capra
Old 10-24-2019, 07:59 AM   #1
Default Jeeper mods a Capra
I got to this thread as it is a little late, but I will be documenting the modification process of my Capra
So far it is a fun little rig my biggest complaint was the manual, which was easily worked around. I ended up choosing ProLine Krawler tires, and for my electronics, I chose a hobbywing 1080, EcoPower WP110T servo, and spekrum radio system. First mods I had to do were more weight, aluminum panels, and aluminum wheels.
ThatJeeper2017 is offline   Reply With Quote
Old 10-24-2019, 08:03 AM   #2
Default Re: Jeeper mods a Capra
First mods in store were some SSD Contenders I had on another truck, and some homemade aluminum panels.
In the wheels I’ve got a nice row of sticky weights which improved the capability a ton. I knew I’d want to run a full droop setup, so I opted for the purple springs in the rear, and red in the front.
Old 10-24-2019, 09:15 AM   #3
Looking real good. I see you are representing the RDC family, thought I was the only one that did that.
MAC FAB is offline   Reply With Quote
Old 10-24-2019, 11:57 AM   #4
I like the look too. Great job on those aluminum panels.
What is the RDC family?
RCTom is offline   Reply With Quote
Old 10-24-2019, 03:14 PM   #5
Thanks! RDC is an off-road racing forum.
Old 10-25-2019, 05:51 PM   #6
First drivetrain mod to the Capra. Bought some incision steel universals for an SCX and they fit perfectly and sound a ton better
Old 10-25-2019, 06:20 PM   #7
Originally Posted by ThatJeeper2017 View Post
First drivetrain mod to the Capra. Bought some incision steel universals for an SCX and they fit perfectly and sound a ton better.
Mine arrived yesterday...but, first, need to resolve the "mysterious" DIG servo problem. Nevertheless, they look great.
~ More peace, love, laughter & kindness would make the world a MUCH better place
Panther6834 is offline   Reply With Quote
Old 10-25-2019, 06:58 PM   #8
It’s a great truck. You’ll have fun with it!
Old 10-25-2019, 09:47 PM   #9
Installed my Incision driveshafts...but, after installing, and then looking at your photos again, I realized I installed them in the opposite direction ("skinny" end on the transmission side, and "thick" end on the axle side. Will that make any difference? Should I reverse them?
Old 10-26-2019, 06:09 AM   #10
I usually run them like this to prevent dirt and sand from getting trapped in them as easily. Either way if perfectly fine though.
Old 10-26-2019, 08:18 AM   #11
I haven't done it yet, as I installed them while at work, but I was planning on putting some grease on the splines. Figured, that would not only smooth extension/contraction movement, but would also "seal" it from anything getting between the two shaft pieces. It's just an "idea", tho...my first crawler, so what do I know...lol
Old 10-26-2019, 02:36 PM   #12
That should work pretty well to keep the junk out of them too. Either way they’re super smooth.
Old 10-26-2019, 02:46 PM   #13
Will find out when I take it for a second "very short" test run, either tomorrow morning, or Tuesday. Gotta get going to work...but, this morning, I installed the brass 6mm wide hexes (so that the 225 hubs are no longer causing problems, plus they added a lil weight), plus I got the primary color sprayed on the body panels. Ok...off to work.
Jeeper mods a Capra - Similar Threads
Capra MODS BEAU Axial Capra 6 10-12-2019 11:07 AM
My Jeeper scaler smokinloon Venom Creeper 2 01-14-2014 11:12 PM
