11-15-2019, 08:02 AM | #41 |
Pebble Pounder Join Date: Mar 2011 Location: Saxonia
| Re: Capra FRO MkII
winch is now working i did a 20k servo on 7.4V with a 1060 esc i wish it could work faster, but i am limited in my abilities and budget on the table https://youtu.be/bRrodOWpgkw rig weight 2.7kg vertical lift https://youtu.be/lItrNGAKR-E |
11-15-2019, 08:33 AM | #42 |
| Re: Capra FRO MkII
the electronics now all in the rear for better balance winch is now outside to produce more / better lever. 90% of using the winch is when the car is flipped to get no minus points beside the winchservo is now enough space for the batterie the rig is now 150gr heavier than first, but durability and easy maintaince are more important |
11-15-2019, 01:43 PM | #43 |
| Re: Capra FRO MkII
the graphite lipos arrived. only 77gr. and nice fitting (no measuring before) :-) |
11-16-2019, 01:48 PM | #44 |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
| Re: Capra FRO MkII
What axle are you running in the front? It looks like the only original capra part is the rear axle. Great performing rig you have built.
11-17-2019, 07:54 AM | #45 | |
Quarry Creeper Join Date: Jun 2007 Location: Loiret, France
| Re: Capra FRO MkII Quote:
11-20-2019, 01:35 PM | #46 |
| Re: Capra FRO MkII
the savöx is to powerful..he is bendin the TFL servomount. so i build a gusset from 1mm cfk for bruteforce stiffness |
11-20-2019, 01:38 PM | #47 |
| Re: Capra FRO MkII
C3 rules want rails minimum on middle of the axles..so i had to dremel out |
11-20-2019, 01:39 PM | #48 |
| Re: Capra FRO MkII
front also shortened to maximal minimal lenght :-) |
11-20-2019, 01:43 PM | #49 |
| Re: Capra FRO MkII
rules want also the lexan shell minimal to the middle of the axkes, so i cutted tiny flares. also need in the rules are "lights". i choosed tamiya ones |
11-20-2019, 01:45 PM | #50 |
| Re: Capra FRO MkII
happy about the lowrider style |
11-20-2019, 01:48 PM | #51 |
| Re: Capra FRO MkII |
11-24-2019, 02:21 AM | #52 |
| Re: Capra FRO MkII
i rised the rear upper links and took them together. so i have more stability and much more ability to climb because the higher links pull down the front |
11-24-2019, 08:00 AM | #53 |
| Re: Capra FRO MkII
todays testrun was great. the rig is now able to climb section with easy with thrilled me before to death... https://youtu.be/m-uHxhyrXsg |
Capra FRO MkII - Similar Threads | ||||
Capra FRO | corefire | Axial Capra | 58 | 11-01-2019 10:50 AM |
New Hulksta Eng. Gspot build mkII | BDR | 1.9 Scale Rigs | 11 | 08-27-2016 10:27 PM |
Skorpion MKII-Milka 2.2 | Frozen W. | 2.2 Scale Rigs | 5 | 02-05-2011 10:54 AM |
1:1 equivalent of RC axles MkII | Crawlerguy851 | Chit Chat | 3 | 10-05-2007 10:56 PM |
