10-24-2020, 11:55 AM | #41 | |
Pebble Pounder Join Date: Mar 2020 Location: Maine
| Re: VFD Capra...Can I Still Call It A Capra? Quote:
Thanks! That's too bad about your chassis. Hopefully they will find another company to get the work done. I'm also looking forward to seeing how your build turns out. It's been one of my favorites on here. No luck with the carbon fiber but there's a member here (JSterrett) that may be able to cut the rails out of aluminum for me. It will be a bit heavier but at this point that's not really a concern. We'll see. Last edited by mjensen; 10-24-2020 at 11:57 AM. | |
10-24-2020, 01:30 PM | #42 | |
Rock Crawler Join Date: Jul 2016 Location: Southern Oregon
Sent from my SM-G970U using Tapatalk | |
10-24-2020, 02:49 PM | #43 | |
I can convert the file to .dxf without a problem. Hopefully the dimensions being metric won't be an issue. I tried to change the design to make it easier to cut. I've removed all the countersinks from the holes as I have a drill press. This should simplify things a bit. I've also made all the holes 3mm but in the event you don't have metric tooling 1/8" should be close enough. I've also made sure all the inside corners have a radius of at least 2mm. If there's anything else you think you might need let me know. I've never used the private message thing here so I don't know if I can send a file with it. If not I'll send you my email address and go from there. | |
10-24-2020, 04:09 PM | #44 | |
10-26-2020, 12:22 PM | #45 |
I got the Capra cage trimmed this morning and it fit surprisingly well. It still needs some tweeks, the 3d printed parts need some paint, and I need to redo the body panels but this is basically what the finished Capra will look like.
11-09-2020, 04:42 PM | #46 |
A quick update. I had hoped to have some progress this past week. Unfortunately life got in the way but I want to thank JSterrett, a member here who, in spite on my ineptitude in figuring out how to send Fusion360 files, managed to cut me a great set of aluminum rails for the Capra. They look so good that it's really a shame that once the Capra is put together they won't be seen. I'm hoping to get them installed this week and finally get this project wrapped up.
11-09-2020, 05:23 PM | #47 |
You know you're doing things right when your end product looks more "factory produced" than the original, factory produced, product. I'm looking forward to hearing how this performs, it looks very well thought out. Keep up the good work!
11-09-2020, 06:45 PM | #48 | |
I really appreciate the compliment but you're giving me far too much credit. This whole project has been a perfect example of someone getting in way over their head with something they (me) knew nothing about. I didn't even have a 3D printer when I started and knew nothing about them. Same for the CAD program, Fusion360. If this thing looks in any way professional it's a complete coincidence. Same for if it actually works. In the end it really doesn't matter because I've had a lot of fun working on it. Should it be a failure I've got a lot of nice parts I can put on something designed by someone that actually knew what they were doing. | |
11-21-2020, 09:11 AM | #49 |
A quick update. I got all the mechanical things put together on the new rails. I debated about painting the rails to match the cage and in the end decided it looked better that way. Unfortunately the new body panels I ordered took some time to arrive so since I don't have a heated place to paint I wasn't able to paint them. In the end I took the body panels and interior off my other Capra so I could see how the truck was going to look. Now I just need to get the electronics installed.
11-21-2020, 10:12 AM | #50 | |
11-21-2020, 01:23 PM | #51 |
| Re: VFD Capra...Can I Still Call It A Capra? |
11-22-2020, 06:57 AM | #52 |
Quarry Creeper Join Date: May 2019 Location: Knoxville
That looks killer!
11-22-2020, 02:55 PM | #53 |
| Re: VFD Capra...Can I Still Call It A Capra? Thanks! I'm pretty happy with the way it looks but how it will drive, who knows. I managed to keep the Capra cage mostly intact so it still looks like a Capra which is what drew me to it in the first place and I made it easier to get to the mechanicals to work on, the biggest issue I had with the stock Capra. I'll admit, the VFD transmission was largely an impulse buy, I thought it looked like a neat system. It turned out to be a pain to actually get into the truck and have the clearances needed for links and the front drive shaft. I almost scrapped the idea a couple of times while I was trying to work things out. Eventually it worked out but it remains to be seen if it was worth the effort. Anyway, I'm working on the electronics tonight and if the snow holds off I might actually be able to get it outside for a test drive this week. |
12-08-2020, 04:40 PM | #54 |
I got a Hobbywing Fusion system for my birthday (I had asked for an Axe system but I decided to keep the Fusion) and since it wouldn't fit in the stock Capra I decided to make it fit in the "sort of a Capra". The VFD transmission only has room for a 540 can motor and a while back I was thinking about trying to do something to fit a 550 motor in it. I decided against it at the time but the Fusion got me thinking about it again. This is what I came up with.
12-22-2020, 08:14 PM | #55 |
With the holidays (and the loss of most of my recent Fusion 360 files, long story) I've not done a very good job of keeping this build updated. But I wanted to wish all of you that might still be following this dumpster fire a Merry Christmas (or Happy Holidays, depending on your preference) and a Happy and more normal New Year. Hopefully in the New Year I'll be able to wrap this project up and put an end to this far too long thread. |
12-22-2020, 08:35 PM | #56 | |
12-22-2020, 10:21 PM | #57 | |
Thanks Jeff. Most of what I lost were files for things to make the 550 length Fusion motor fit the rails you made me and the VFD transmission. I was using Fusion under an educational license I had from Autodesk for an Inventor course I took a few years ago when I was laid off. It expired unexpectedly and I wasn't able to cache the work I was currently doing, probably user error. When I install the free version of Fusion all my old files were there but nothing from the last month or so. I've slowly been trying to reproduce the lost files from derives of older files so all is not lost but it just takes time. Once the holidays are over I'll have more time to figure it out and if you do decide to try the build and want to put a 550 can motor in it let me know and I'll sent you all the updates. | |
01-29-2021, 03:40 PM | #58 |
I'm honestly surprised this thread is still getting views and I apologize for not being able to update it. 2020 went out with a bang for my family with my elderly mother's house being gutted by fire a few days after Christmas. Fortunately she was fine and she was well insured but losing 88 years worth of belongings and mementos has been hard on her. So my retirement came to an abrupt end as I now need to deal with insurance people, cleaners, building contractors, etc which doesn't leave me much time for RCs. I had really hoped to have the Capra done by now and I already had a new project planned using the TRX6 my dog got me for Christmas (not sure how he could afford it but I suspect he might have been dealing doggy treats down at the local dog park) Anyway, with my virus money I picked up a cheap CNC router and some 3mm carbon along with another VFD transmission and I figured on starting another year long excruciating trial and error build, this time with 6 wheels, to keep me occupied. Hopefully it will still happen but I doubt it will be anytime soon. Thanks again for the interest in the Capra. I will definitely get it done eventually. |
01-29-2021, 06:39 PM | #59 |
Rock Crawler Join Date: Dec 2005 Location: Marietta
Sounds like you have way more important things to work on than tiny trucks. Take care of what's important and let the other stuff come as it may.
01-30-2021, 07:35 AM | #60 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
Your dog sounds a little shady... Sorry to hear about the fire, lack of hobby time is understandable. I look forward to updates on this, and future projects! |
VFD Capra...Can I Still Call It A Capra? - Similar Threads | ||||
Capra’s on 2.2 | solo1 | Axial Capra | 10 | 12-22-2020 02:30 AM |
My Capra | dezracer99 | Axial Capra | 15 | 05-12-2020 10:42 AM |
Used Capra | Jbird123 | General Crawlers | 9 | 12-28-2019 04:50 PM |
Capra with 2.2s | Mr. Crawley EC | Tires and Wheels | 5 | 12-17-2019 07:06 AM |
Capra 2.2 | mccarsones | Axial Capra | 23 | 10-19-2019 03:19 PM |
