Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Capra
Thread: Axial Unimog wheels on a Capra
Old 05-05-2020, 01:00 PM   #1
Default Axial Unimog wheels on a Capra
Has anyone tried these wheels or have a set they can compare with the stock wheel?
Axial Racing - 1.9 MW19 Beadlock Wheels - Black (2pcs)
rbronco21 is offline   Reply With Quote
Old 05-08-2020, 10:05 AM   #2
Default Re: Axial Unimog wheels on a Capra
I have both rigs. The Unimog wheels rub slightly on the Capra's portal housing. If you really had too, I think you could get enuf clearance by taking a Dremel sanding drum to it, tho I wouldn't really recommend that. I used the SSD steel wheels which fit great and add a little weight where needed.
https://www.amainhobbies.com/ssd-rc-...oaAuMeEALw_wcB
JimInMiami is offline   Reply With Quote
Old 05-08-2020, 11:32 AM   #3
Dang, I was hoping they were the same inner and lock ring and just used a different outer for the cosmetics. Thanks for the info. Hmm, do you think they're compatible? Could I use Capra parts with the Unimog outer?
Old 05-08-2020, 11:35 AM   #4
I do like those wheels. I'm old school for off-roaders. I love hummer wheels and steel wheels and the Unimog ones look alot like the hummer's.
Old 05-08-2020, 12:56 PM   #5
Here's my Capra with the SSD's
if I get a chance this evening, I'll check to see if the Capra inners match the Unimog outers.
Old 05-08-2020, 03:44 PM   #6
Nice and simple. I have the Axial plastic wheels that look like that. I got them years ago for my Losi MRC and they look great on there, but they don't fit over the Capra portal boxes.
Old 05-09-2020, 04:11 PM   #7
Just so happen to be swapping a set of the wheels out on another build.
It’s a little tight up too with the SSD brass portal weights, but I don’t see any places they’re rubbing
cowsgomoo is offline   Reply With Quote
Old 05-23-2020, 11:03 AM   #8
I got some UMG10 wheels and they do fit a bit tighter than the stock ones. I can now see what you mean by the improved plastics in the latest kits. Anyway, it was simple to clearance the brass with a file.
