05-10-2020, 05:04 PM | #1 |
Rock Stacker Join Date: Oct 2008 Location: Long Beach
| Start up with 4WD engaged instead of freewheeling?
I'm new to digital radio adjustments and I'm setting up my dig to freewheel using a DX5 Rugged. Freewheeling is in the center, then you go either direction for dig or 4WD. Can the order be swapped? Can I start in 4WD, click once for freewheel, and again for dig? Here's a simpler question. I think I have my endpoints set correctly. I'm a few clicks away from stalling the servo when I dig or go to 4WD. I have SSD aluminum mounts and a Savox SH-0265MG. The servo is powerful enough and the mounts stiff enough that it twists up the chassis is it can't engage. 4WD may stall while sitting still, but once you hit the throttle, the plates line up and it locks up. Dig sometimes stalls and I can't figure out how to rotate the internals to make it engage, but when it does engage, it's perfect. I can throttle or twist the rear output and nothing locks into place. I didn't lubricate anything in the dig box since there was nothing lubed in the instructions. |
05-12-2020, 12:10 PM | #2 |
| Re: Start up with 4WD engaged instead of freewheeling?
I'm going to post the first question to the DX5 Rugged thread, but I have a thought about dig not engaging. I was trying to verify everything with the trans bolted to the skid, so I wasn't rotating the rear output to see if that helps engage the dig. Turns out that does help and it seems to be pretty consistent. I'm finishing my build and will make sure everything works once it's running.
05-12-2020, 12:25 PM | #3 | |
RCC Addict Join Date: Mar 2019 Location: Hemet
| Re: Start up with 4WD engaged instead of freewheeling? Quote:
Hope this helps | |
Start up with 4WD engaged instead of freewheeling? - Similar Threads | ||||
Understanding ESC freewheeling | TDanny | Electronics | 33 | 09-25-2019 09:18 PM |
I got engaged | djjiz | Chit Chat | 91 | 10-20-2015 01:03 AM |
should these axles be spinning freely? (freewheeling) | 53 willys | Axial XR10 | 14 | 10-31-2010 08:47 AM |
Just curious, but would this work to prevent a nitro crawler from freewheeling? | Krawlin | Chit Chat | 11 | 09-17-2007 10:21 PM |
