07-02-2020, 04:22 PM | #1 |
Rock Stacker Join Date: Feb 2017 Location: United States
| 48 pitch 11 tooth pinion gear?
Hello friends, I want to swap out the stock 14 tooth pinion gear for a 11 tooth pinion gear in my Capra, but try as I might I cannot find one that is 48 pitch. I see that there are plenty of 32 pitch pinion gears available. Can I use a 32 pitch 11 tooth pinion gear in the Capra?
07-02-2020, 04:45 PM | #2 |
Quarry Creeper Join Date: Sep 2012 Location: Emmaus, Pa
| Re: 48 pitch 11 tooth pinion gear?
The Capra takes 32 pitch pinion , I have an 11 tooth and it’s perfect imho for my setup.
07-02-2020, 05:58 PM | #3 |
Well if for some reason you do happen to need 48P RRP makes an 11T https://www.rpphobby.com/product_p/rrp1411.htm |
07-02-2020, 07:24 PM | #4 |
It's 32 pitch? Huh, on page 23 of the online manual it lists AX30569, which is a 48 pitch 14 tooth pinion gear. I'm so confused. Did they switch to 48 pitch gears at some point or vise versa?
07-02-2020, 07:32 PM | #5 |
I dont have a Capra but looking at parts it does appear to be 48P EDIT: hmmm I'm confused now too looking at the gear set most are 48P but the spur does look like 32P https://www.amainhobbies.com/axial-c...2/p1049129?r=0 Open it up and check? Last edited by HumboldtEF; 07-02-2020 at 07:36 PM. |
07-02-2020, 07:49 PM | #6 |
Newbie Join Date: Aug 2014
This is what I am using AXI30722 Axial 32P Pinion Gear w/3mm Bore (11T) |
07-02-2020, 09:24 PM | #7 |
Pinion gears aren't that expensive. I'll give a 32 pitch a try and if it doesn't work I'll get the 48 pitch. Thank you guys for your insight and assistance. |
07-03-2020, 03:30 AM | #8 |
Trust me , it’s 100% 32 pitch
48 pitch 11 tooth pinion gear? - Similar Threads | ||||
How many tooth pinion gear for 45T motor? | GTSLOW | G-Made Crawlers | 2 | 10-04-2015 10:27 AM |
Bully pinion gear - what tooth and pitch? | Tomy | RC4WD Bully | 1 | 04-18-2009 10:17 AM |
