Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Capra
Thread: Treal brass knuckles and covers installed and tested
Old 07-06-2020, 10:12 AM   #1
Default Treal brass knuckles and covers installed and tested
Loving it now!
https://www.youtube.com/watch?v=Gx0JCk_BZzg
Some questions:
- I'm interested in a flat skid. What are the best options around
- I want to lower the gearing more than the stock spec allows. How do I fit a smaller pinion?
- How do I narrow the stance? Does that work better than stock width?
thank you,
fc
rcreview is offline   Reply With Quote
Old 07-06-2020, 10:44 AM   #2
Default Re: Treal brass knuckles and covers installed and tested
Vader and ucfab makes a nice delrin flat skid.
Tgh wheels to narrow it as much as possible.
I run a 11t with a revolver 1800kv, and see no need to lower even more, but some guys can mount a 10t pinion with other motor mount skrews.
For a 9t, i guess you need a treal or vitavon trans case.
Rcdood is offline   Reply With Quote
Old 07-06-2020, 12:31 PM   #3
I put a Treal case in mine and am running a 9t with a Crawlmaster 16t Pro. Thing will crawl so slow the wheels will barely turn. I heard someone mention being able to use the 2 different holes in some of the HH motors to allow a 9t with the stock transmission case but have no idea if that's true or not.
bexline is offline   Reply With Quote
Old 07-06-2020, 12:42 PM   #4
What about the Treal aluminum skid? I know some cheaper aluminum isn't awesome and tends to hang up but I don't know if the type Treal uses is the crappy kind or not.
Treal brass knuckles and covers installed and tested - Similar Threads
Treal overdrive gears installed and tested JMHZ2401 Redcat Crawlers 2 11-06-2019 06:25 AM
Brass covers chino63 Traxxas TRX-4 2 02-10-2018 04:27 PM
Brass portal covers(knuckles) front and rear option geauxktm, Traxxas TRX-4 7 10-11-2017 05:22 PM
Inner Brass Portal Covers. djmaincheese Traxxas TRX-4 13 09-27-2017 02:17 AM
Hot Racing Brass Knuckles and SSD Brass Weights compatibility saddlesore Axial SCX10 II 5 07-15-2017 04:27 PM
