07-29-2020, 04:04 PM | #1 |
Newbie Join Date: Mar 2008 Location: Merced
| SCX10.3 Rear Portal Housing swap possible?
I was looking at the Rear Portal Axle on the SCX10.3 and was curious if anyone knows if they could be swapped out with the stock rear portal on the Capra. I would like the benefit of running my links up top the axle vs how the capra has it set up. |
07-29-2020, 04:26 PM | #2 |
I wanna be Dave Join Date: Sep 2019 Location: US
| Re: SCX10.3 Rear Portal Housing swap possible?
Don't quote me on this...but, if I recall correctly, the Capra & SCX10.3 use the same axles. ~ More peace, love, laughter, & kindness would make the world a MUCH better place |
07-29-2020, 04:38 PM | #3 |
Sounds good, just bought a housing and i guess ill find out in a week or so. Thanks for the reply.
07-29-2020, 04:48 PM | #4 |
I wanna be Dave Join Date: Jul 2010 Location: Toronto
| Re: SCX10.3 Rear Portal Housing swap possible? |
07-29-2020, 04:53 PM | #5 |
07-29-2020, 05:15 PM | #6 |
Newbie Join Date: Jun 2019 Location: Las Vegas
Supershafty.com has an aluminum rear link relocator for $22. It bolts in solid to the axle where the old links attached. Sounds like this could work for you. Sent from my Pixel 3a XL using Tapatalk |
07-29-2020, 05:55 PM | #7 |
I purchased this one already and it will work fine. I was just hoping I could swap axles.
05-18-2021, 07:32 PM | #8 |
Quarry Creeper Join Date: Jan 2016 Location: Southampton
In case you are still wondering.... I put an SCX10 iii axle in my Capra based comp rig. Bolted right in. It changes the position of the top mount, which what I wanted also. It will also allow narrower track width as it is narrower than the Capra. All the gears are the same but you will need the SCX10iii axles, they are shorter. You will also need the axle case diff cover. Odd it doesn't come with the housing. Took me longer to locate the cover than anything else. I finally ordered one aftermarket. Good luck
SCX10.3 Rear Portal Housing swap possible? - Similar Threads | ||||
Portal swap to scx10 ii axles/ gear change? | jacobmc | Redcat Crawlers | 0 | 02-21-2020 06:58 PM |
IN STOCK NOW the NEW SSD SCX10 II Portal Knuckles & Rear Axle! | RPP Hobby | RPP Hobby | 3 | 02-04-2019 03:31 AM |
Shapeways 3d printed portal axles, knuckles, t-case, axle housing for scx10 | Shinjari | Axial SCX-10 | 29 | 09-28-2016 06:48 PM |
