Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Capra
Thread: Do I have a rear axle problem?
Old 09-30-2020, 08:03 AM   #1
Default Do I have a rear axle problem?
Building the kit.
After finishing the two axles I noticed that I can grab the wheel hex hub and spin them freely in either direction for the front axle. Nice and smooth.
But for the rear axle I can only do it spinning as if it was going backwards. Spinning the hex hub in the forward direction jams the gear inside the diff, preventing further rotation.
However I can take the input shaft of the rear axle and spin it freely in either direction.
I find it strange that the rear axle doesn't behave like the front axle.
Is this an issue?
Kingmeow is offline   Reply With Quote
Old 09-30-2020, 08:07 AM   #2
Default Re: Do I have a rear axle problem?
probably. id disassemble and check to see if everything is correct and the correct bolts are used. Are you using the printed instructions or the downloaded ones? I built my kit from the downloaded ones even though the version number matched the printed manual that came with the kit.
splyn is offline   Reply With Quote
Old 09-30-2020, 08:17 AM   #3
My printed manual part number matches the online PDF version but I used the online PDF version just in case.
I'll take it a part and see. Luckily the axle has not been installed yet.
Old 09-30-2020, 08:46 AM   #4
Probably nothing wrong.
Attach the center shafts and try again. The center shafts act as a spacer and keep the input gear from getting "pulled into" the ring gear and binding. Not sure why one axle does it and the other doesn't, but it's a common question that comes up with hypoid gears.
OSRC is offline   Reply With Quote
Old 09-30-2020, 12:47 PM   #5
Also make sure that the 4 “3rd member” screws are not overly tight, just snug.
Fricker08 is offline   Reply With Quote
Old 09-30-2020, 07:20 PM   #6
I was starting to think this right after I started the thread. I figure it was the spiral cut gears (hypoid) that were jamming up in one direction and not the other. Your post solidify my thinking. Like you said, as to why the front axle is spinning easily both ways and not the rear axle, who knows.
Right now I only have two axles built so can't attach the center shaft to the drive shaft. Instead, I took a small string and tied something lightweight to the center shaft. I used the tire wrench that came with the kit.
Even with that light weight, I had it hanging off the shaft (pointing down) like a Christmas ornament. Low and behold, smooooth as butta' when turn in either direction via the hex hub! No locking. No jamming.
Glad I tested this theory out before I went disassembling everything.
What is the "3rd member" screws? The four screws that hold the diff or pumpkin cover on to the axle? If so, I only have those snug. The four portal cover screws are also snug.
Old 09-30-2020, 10:49 PM   #7
Yea the pinion case to the diff housing. Good deal, didn’t mean to state the obvious
Old 10-01-2020, 07:51 PM   #8
No, no, sometimes you need to state the obvious when you are staring at the tree and miss the forest! My wife always states the obvious to me, often many times over!
Do I have a rear axle problem? - Similar Threads
Problem with rear axle Newfie Redcat Crawlers 8 04-17-2013 11:02 PM
Rear axle problem tinycrites Axial Wraith 7 03-04-2012 08:45 AM
Super Rear Axle Problem Real Hustler Superclass Crawlers 4 10-11-2010 10:26 PM
cc-01 rear axle problem akhoundog 1.9 Scale Rigs 7 04-30-2007 01:15 PM
Rear Axle Problem txrenegade General Crawlers 1 02-09-2006 04:06 PM
