03-25-2021, 06:15 PM | #1 |
RCC Addict Join Date: May 2009 Location: In the warmth!
| Robotboy's Puzzled Goat
Something I've been working on here and there. Pretty much a done deal, just a few loose ends to tie up. It's puzzled cause it's pieced together from lots of different rigs. Initial testing went super and I'm already pleased with it. A little more tinkering will be done. A puzzled goat...not much Capra to it... Specs, as of now: SSD Pro44 front axle, BPC servo on axle mount, SSD aluminum C's, SSD aluminum link mounts and SSD brass knuckles for Enduro (cause I had them ). SSD Pro44 rear axle, SSD aluminum link mounts and SSD brass weights. Capra cage, interior and body panels. Element Stealth trans w/ machined gears, OD. Spare-Time Hobbies flat capra skid for stealth trans. Hobbywing 1800kv Fusion motor/esc. GPM hardened steel spur and aluminum spur adapter. CC BEC, waterproofed. Husky hi-clearance steel lower links. Factory Team hi-clearnce steel upper links. Element Gold shocks. SPT 35kg servo. MIP driveshafts. RC4WD 1.9 MT Baja Pro X Tires. Chanquish 2.2 Aluminum beadlocks. Last edited by Robotboy; 04-02-2021 at 01:17 PM. |
03-29-2021, 02:08 PM | #2 |
Pebble Pounder Join Date: Dec 2008 Location: Close
| Re: Robotboy's Puzzled Goat
I like it! I have a Stealth trans sitting here and I'm thinking about putting it in my Capra.
04-02-2021, 01:24 PM | #3 |
PG got some new shoes. RC4WD 1.9 MT Baja Pro X on the 2.2 Beads. Liking the look and feel of them. Sticky and soft. Did great on the test run! Here's some posers with the new shoes.... |
Robotboy's Puzzled Goat - Similar Threads | ||||
Robotboy's Trailrunner | Robotboy | Element RC 1/10 Enduro Trail Truck Sendero | 11 | 09-16-2020 05:33 AM |
Robotboy's Wreckluse | Robotboy | 2.2 Scale Rigs | 19 | 01-23-2012 10:56 AM |
LCC up in smoke... A little puzzled??? | country_crawler | Electronics | 6 | 02-21-2011 02:23 PM |
ok now i'm puzzled on wiring......... | bob1961 | Electronics | 8 | 11-28-2008 06:27 PM |
axle problem, im puzzled | davidcrawls | Tamiya TLT Crawlers | 5 | 07-13-2006 10:48 PM |
