03-31-2021, 09:17 AM | #1 |
Quarry Creeper Join Date: Feb 2012 Location: New Hampshire
| Dig Position Question
I'm wondering how everyone is running their dig setup? Do you use it as a 2 position with locked and driven or 3 position with locked, freewheel and driven? I burned the sx107 servo out and while I believe it was likely the EPA's not adjusted correctly I also had it set on the 3 position switch and was wondering if that was also causing issues. |
03-31-2021, 09:31 AM | #2 |
Pebble Pounder Join Date: Feb 2019 Location: SIGNAL MOUNTAIN
| Re: Dig Position Question
I've only had the Capra built up for a week now, but using the dig as 3 position. PowerHD micro servo and GT5 transmitter. I set themicro servo endpoints really low (@20%) before I powered it up and adjusted from there. So far so good.
04-02-2021, 07:04 PM | #3 |
I'm using the dig as a 3 position with a Hitec 225mg servo mounted upside down sticking out the bottom of the "fuel cell" with a homemade link and a red kimbrough saver. Works mint. I'm not sure the stock saver is precise enough to reliably use the middle freewheel position. The rtr dig servo is IMO a ticking timebomb at best, regardless of how you set the EPA or what you use for a saver/linkage. |
Dig Position Question - Similar Threads | ||||
dx3e 3 position dig question | Slowbro | Electronics | 5 | 06-30-2011 02:55 PM |
Anyone using a 2 position switch with the dig?? | ripper7777777 | Team Losi Comp Crawler | 24 | 06-18-2009 03:52 PM |
6EX with 3 position dig? | DesertCrawler | Electronics | 3 | 04-13-2009 05:08 PM |
2 Position Dig | Harvo | Newbie General | 11 | 09-01-2008 09:00 PM |
