Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Capra
Thread: 4WS: Anyone done it, WITHOUT cutting up the Chassis?
Old 09-23-2021, 07:13 AM   #1
Question 4WS: Anyone done it, WITHOUT cutting up the Chassis?
Everything that I seen in the videos & read on these forums, says the rear steering servo will bang into the chassis during a crawl.
Solution is to cut away parts of the chassis, to prevent the top of the rear steering servo from hitting the chassis.
Has anyone tried another solution? These come to mind:
  1. Smaller servo (e.g. https://www.savoxusa.com/collections...el#description)
  2. 3rd party chassis
Thinking HH SHV800 as a rear (and front) steering servo, but would rather avoid surgery on a new Capra kit.
8300Angstroms is offline   Reply With Quote
Old 09-24-2021, 01:31 AM   #2
Default Re: 4WS: Anyone done it, WITHOUT cutting up the Chassis?
You can get away with just removing the lower bracing, but the servo can hit on full bump. When flexing one way or the other it will clear.
(This is on AR44, but its the same story on Capra axles)
MikaelBerberg is offline   Reply With Quote
Old 09-24-2021, 04:38 AM   #3
So even a 1" high servo will still bang into the chassis? (Never seen a Capra in person.)
What about this chassis, by SuperShafty? https://supershafty.com/products/sup...ckage-upgrades
It looks like it has the clearance on rear, even for a 40mm high servo.
Old 12-02-2021, 11:35 AM   #4
JMo
You could could just fit some longer rear links and a prop shaft, and stretch the wheelbase so the rear servo clears the cage... but that would probably negate much of the benefit of having 4WS in the first place of course.
ps. I imagine at some point Axial will release the 4WS cage parts as spares, so you could probably just buy those in future.
JMo is offline   Reply With Quote
Old 12-02-2021, 08:31 PM   #5
The new 4ws cage is pre-orderable on horizon's website
AXI231045 - Black
AXI231044 - Red
2wheeler is offline   Reply With Quote
Old 12-05-2021, 01:48 PM   #6
Check this fella out- https://www.youtube.com/watch?v=y_wRq1mh_7w
He basically lets the cage sit on the servo, seems like it is a non-issue.
slashracer111 is offline   Reply With Quote
Old 12-05-2021, 07:13 PM   #7
AXI231045 - Black
AXI231044 - Red
I wonder how much trouble it will be to swap out the different parts onto an already assembled capra. Looks to me like the cage sides and fuel cell are different. Not sure what else, would love to see a side by side comparison of the two cages. Been a while since I assembled my kit.
BSmith is offline   Reply With Quote
4WS: Anyone done it, WITHOUT cutting up the Chassis? - Similar Threads
Cutting the Wraith Chassis dcwhite Axial Wraith 31 08-13-2015 10:59 AM
Cutting chassis bigdodge88 Tools, and Procedures 2 11-11-2008 06:33 AM
cutting tranny when cutting bottom of chassis off... dieselfuel Newbie General 1 02-23-2006 08:10 PM
cutting the chassis jordanator62 Tamiya Txt-1 and Juggernaut 16 07-18-2004 07:20 PM
