12-28-2021, 03:28 PM | #21 |
Rock Crawler Join Date: Jul 2016 Location: Southern Oregon
| Re: Multi-transmission Capra chassis
VFD version is pretty close. It’s drivable, but I want to shorten up the front links and probably swap to softer springs… did manage to get everything low enough that I won’t have to cut up the interior. Had to trim down the bullet plugs though… Sent from my iPhone using Tapatalk |
01-20-2022, 11:14 PM | #22 |
Newbie Join Date: Jul 2017 Location: Redding, CA USA
I was going to suggest putting in a Mamba X and sensored motor when I first saw your build. Looks like you did . Best upgrade I ever did on all my crawlers. And most expensive...lol |
02-10-2022, 07:13 PM | #23 |
Quarry Creeper Join Date: Nov 2018 Location: So Cal
Awesome work! Did you make any gearing changes to the VFD trans to compensate for the reduction in the 10.3 AR45 portal axles? I'm building another Capra with a 3-Gear (AX10) trans and 10.3 AR45 portal axles. By my calculations the final drive ratio with the typical 13T pinion and 56T spur of the 3-Gear trans ends up around 81:1. I do like it low, but not that low. I think I'm going to have to go with a 20T pinion or put overdrive gears in both F&R portal axles to bring it back up to where I like it 45-50:1. Also - do you have any plans to make your servo on axle mount for the AR45 portal axles available for sale? I am not finding any SOA mounts for the AR45 portals, just the AR45 straight axles. I really don't want to have to go CMS on this rig. |
02-11-2022, 08:43 AM | #24 | |
| Re: Multi-transmission Capra chassis Quote:
I’m running stock-ish gearing (15T I think), but switched to 4S to get some wheel speed back. I think I made enough parts for two more SOA mounts, shoot me a PM. Sent from my iPhone using Tapatalk | |
04-24-2022, 08:51 PM | #25 |
A little more work today, but mostly cosmetic. Paint job on the aluminum panels was having adhesion issues, so I decided to try out my wife’s Cricut and some vinyl… I see so many possibilities for the future! Sent from my iPhone using Tapatalk |
04-28-2022, 03:16 AM | #26 |
Pebble Pounder Join Date: Mar 2020 Location: Maine
You've done such a great job on this. It turned out much better than what I had imagined when I first started on mine!
Multi-transmission Capra chassis - Similar Threads | ||||
Capra transmission | Rick_Sharp | Axial Capra | 9 | 07-02-2022 07:33 PM |
Anyone with multi-speed transmission? | jayliu1984 | General Crawlers | 3 | 03-27-2008 08:39 PM |
Multi-Speed Transmission For Z3025 | DKNguyen | General Crawlers | 4 | 02-23-2007 09:50 PM |
