07-21-2022, 05:09 PM | #1 |
Newbie Join Date: Mar 2022 Location: Norcal
| Capra Tranny for straight axles
Help me out guys, please I got a capra kit and stole the axles for a gspeed build Now I want to build the capra with the ar45 straight axle kit, for fun But I know I will need a different tranny, and probable skid Please list some good options for me, for the tranny and skid to bolt it in Thank you |
07-22-2022, 11:13 AM | #2 |
RCC Addict Join Date: Aug 2005 Location: Oceano, CA
| Re: Capra Tranny for straight axles
Standard Axial 3-gear seems to be the go-to, but an element trans may also work. UC Fab and Vader both makes skids, not sure if there are other options out there
07-22-2022, 11:30 PM | #3 |
Quarry Creeper Join Date: Jan 2021 Location: in the Canyon
Vader 3-gear adapter, and your choice of trans. If you want to keep dig, the Amazon-sourced Que-T gearbox offers a quite good clone of a Hurtz dig. If you're not set on dig, the Element Stealth is super smooth. I've built up a Capra cage with all Element underneath and it's fantastic.
07-23-2022, 09:17 PM | #4 |
RCC Addict Join Date: Jun 2008 Location: Mudville
You could go with SSD Diamond axles. You can flip the R and P gears in them. SSD Wraight High Speed Tranny. |
09-16-2022, 06:08 PM | #5 |
Quarry Creeper Join Date: Jan 2016 Location: Southampton
I second the stealth transmission. I put AR60s in mine and it worked great with the stealth. The only problem you may have is drive shafts hitting the links. I cured that by bending the upper link slightly and offset rod ends. Good luck.
11-26-2022, 05:32 AM | #6 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
This thought crossed my mind as well. I was thinking the stock trans along with a Revolver Snubnose and an RC4WD 4:1 GRU may work for non-portal axles.
Capra Tranny for straight axles - Similar Threads | ||||
Capra straight axles | DTA510 | Axial Capra | 7 | 04-22-2022 05:51 PM |
Fricker08’s F9 straight Capra | Fricker08 | 1.9 Scale Rigs | 20 | 11-28-2021 03:30 AM |
A straight capra | JKMIDDY22 | 1.9 Scale Rigs | 12 | 12-08-2020 05:12 AM |
RC Axle Master's Straight 4340 Chromoly Straight Axles | Cruzin Illusion | EnRoute Berg | 48 | 08-29-2009 06:07 PM |
