10-21-2022, 08:30 PM | #1 |
Rock Stacker Join Date: Sep 2022 Location: Central CT
| 4ws - keep your servos the same direction
Tiny tip as I'm figuring out this 4ws thing. As you assemble the axles, it doesn't really matter which direction you put the rear servo/axle. But if you put its the same direction as the front, when you are dealing with removing the body for service, it gives you a tiny bit more slack on servo wires if you keep them pointed the same way. This is a fun truck, but a bit of a pain to rewire everything - this helps a bit. My cutoff is when I have to unscrew the frame and remove the cockpit/guys which is a bit of a pain. |
10-21-2022, 11:56 PM | #2 |
Rock Stacker Join Date: Nov 2015 Location: Chilton County
| Re: 4ws - keep your servos the same direction
Nobody says you have to put the cockpit back in?
4ws - keep your servos the same direction - Similar Threads | ||||
Castle BEC 2.0 dual wire, 4ws, 2 servos, Holmes bypass??? | Turtlejon | Electronics | 3 | 09-14-2018 09:02 PM |
BEC and 4ws dual servos, intermittent power | chalmene | Electronics | 14 | 08-28-2016 03:10 PM |
Help wiring 2 servos for 4ws with 2ch radio. | Bracz | Electronics | 3 | 06-13-2012 04:48 PM |
how do I wire/solder 2 CC 10A BECs for 4WS (2 servos)? | ussprinceton2004 | Axial Wraith | 23 | 01-29-2012 08:24 PM |
