Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Capra
Thread: Slow it down?
Old 04-23-2023, 12:05 AM   #1
Default Slow it down?
Hi,
Got my first crawler, Capra FWS 1.9 but it’s way faster than I expected.
I expected a nice slow adjustable crawl but the throttle is either on or off, way too fast. I’ve adjusted the transmitter to the 25% setting.
Tried my sons new crawler (different make), yesterday and it handles as I expected mine to, nice slow crawl.
How to rectify? Change, motors, battery, transmitter?
Gazza19 is offline   Reply With Quote
Old 04-23-2023, 03:18 AM   #2
Default Re: Slow it down?
I started with an RTR but never ran it with the included transmitter, I used my FlySky FS-GT5.
You should have some varience in speed, sounds like something isn't right to me but hopefully someone that knows better will pipe up.
I also went with a Castle Creations Mamba Micro system.
May want to look at changing the pinion, think 11t is the smallest you can go w/o modding the trans, then maybe swapping the ESC and/or motor.
Actually, if you go through the ordeal of swapping pinions, I'd highly recommend motor too while you're in there.
Also, if you recently got it yopu can try shooting off an email to Axial support https://www.axialadventure.com/contact
Thorsteenster is offline   Reply With Quote
Old 04-23-2023, 07:01 AM   #3
I don't know about fitment for the stock vehicle as the only thing left from my original Capra is the axles. However, if you haven't tried a HobbyWing Fusion Pro, you owe it to yourself to give it a try. Amazing throttle control, good adjustability (you need to get the programming box), and rock-solid reliability so far. Any of the Fusions would be worth a try. The SE is really affordable.
BR549 is offline   Reply With Quote
Old 04-23-2023, 08:35 AM   #4
there was a engineering failure on this one
the one fix that seems to solve the issue is to revert back to a 3 gear transmission
ferp420 is offline   Reply With Quote
Old 04-23-2023, 08:40 AM   #5
Just ordered the Fusion Pro, thanks for the advise
Old 04-23-2023, 08:55 AM   #6
thats a good bandaid it still wont solve the gearing issue
keep a eye on your temps on that motor as long as the motor stay cool your good
Old 04-23-2023, 09:20 AM   #7
While you're replacing the motor definitely drop to an 11t pinion. 10t with some mods to the motor's screw slots on the trans if I recollect correctly.
Old 04-23-2023, 07:06 PM   #8
This. The stock trans is way too high geared. You can try and bandaid the problem but the easy fix is swap to a 3-gear. Options range from a simple skid swap to major chassis mods.
JSterrett is offline   Reply With Quote
Old 05-05-2023, 07:27 AM   #9
Nice rig . What wheels are you running.
MAC FAB is offline   Reply With Quote
Old 06-06-2023, 02:23 PM   #10
The ones in those pics were just stockers off a 10.3 Bronco. That was kind of a prototype rig for that chassis that I ended up selling
Old 08-20-2023, 10:09 AM   #11
What is your crawl ratio with the 3 gear trans?
Weezul is offline   Reply With Quote
Slow it down? - Similar Threads
Austin's Slow SCX-10 build Turned Slow Wroncho build austinc2099 Axial SCX-10 35 10-25-2018 09:38 PM
Slow down ManiacMagoo Chit Chat 12 12-15-2015 08:55 AM
how slow??? rockhound Tamiya TLT Crawlers 5 12-09-2004 10:29 AM
