03-10-2016, 09:56 PM | #1301 |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
| Re: Axial rr10
How did you manage that? Sent from my SM-N910V using Tapatalk |
03-10-2016, 10:00 PM | #1302 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Axial rr10
I went through 4 cases before throwing it in a box and buying an alloy cased servo. Brushless motors and solid locked axles break stuff.
03-10-2016, 10:02 PM | #1303 | |
| Re: Axial rr10 Quote:
Did you run into something with the servo? Sent from my SM-N910V using Tapatalk Last edited by DowntownScience; 03-10-2016 at 10:06 PM. | |
03-10-2016, 10:13 PM | #1304 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Axial rr10
Downtown, I bet you will be fine with plastic case unless you drive your shit into the ground like maslin. |
03-10-2016, 10:43 PM | #1305 |
| Re: Axial rr10
1283sg has been going strong for a while now. I don't run my stuff in to the ground, but I do run it hard, and nearly an hour every day. I'm still trying to find a weak spot on the bomber, it's holding up well. |
03-11-2016, 08:29 AM | #1306 |
| Re: Axial rr10 |
03-11-2016, 08:43 AM | #1307 |
| Re: Axial rr10 After reading his Wraith thread, I thought Maslin was just one of those people who could break a brick with a pillow. Then I drove a buddy's decently fast Wraith and the Hitec servo case didn't last more than a couple less than perfect jumps (not insane crashes either). I realized he was right about aluminum cased servos for these trucks.
03-11-2016, 08:46 AM | #1308 |
| Re: Axial rr10
Oh great! Only time will tell! 1230sg in my bomber which I plan to use on the track. Sent from my SM-N910V using Tapatalk |
03-11-2016, 08:51 AM | #1309 | |
| Re: Axial rr10 Not stock at all. Never even plugged a battery in stock Quote:
03-11-2016, 08:53 AM | #1310 |
| Re: Axial rr10
Can you provide a picture of the dlux truss and servo mount? I think I've read of this and seen pictures but this is my first ar60 axle truck and am not sure of how to configure this. Sent from my SM-N910V using Tapatalk |
03-11-2016, 09:02 AM | #1311 |
| Re: Axial rr10
Nevermind! Google'd it. Are they all carbon fiber? Is the a drag link you can purchase that is designed for a servo in this position or do you need to make your own? Sent from my SM-N910V using Tapatalk |
03-11-2016, 09:07 AM | #1312 |
| Re: Axial rr10
The older ones were carbon, but they were breaking I think? They are now G10. The steering link and upper links will have to be made.
03-14-2016, 07:20 AM | #1313 |
Rock Stacker Join Date: Feb 2016 Location: Under Your Hood
| Re: Axial rr10
Did a lot of testing and tuning this weekend. After breaking my last rear upper link I had in stock, in a pinch I used a spare set of RTR rear lowers in place of the uppers and it works great! No clearance issues... cartwheeled on the street twice, 4 flip endo while coming down a field at full speed and braked too hard and nothing broke at all. Also went from a 30wt to a 15wt in my dual Pro-Line setup (all around) and couldnt be happier with the current setup. |
03-14-2016, 09:02 AM | #1314 |
| Re: Axial rr10
I had a handful of full speed barrel rolls yesterday as well. Dlux truss worked great, bent both rear axles Really happy with the Bomber, it just works. |
03-14-2016, 09:12 AM | #1315 | |
Im so freaking pleased how my Bomber is set up right now, 6 packs straight and no broken bits...this after not being able to get thru a full pack without something breaking for the past month or so. Soon as my white Methods come in ill take some updated pics. | |
04-07-2016, 11:29 AM | #1316 |
RCC Addict Join Date: Aug 2005 Location: Oceano, CA
| Re: Axial rr10
bringing this one back up... has anyone else put their hands on the new R35 KR2s yet?
04-07-2016, 01:00 PM | #1317 |
| Re: Axial rr10 Then we crawled for a while. Good day on the rock pile. |
12-28-2016, 05:04 AM | #1318 |
Pebble Pounder Join Date: Mar 2012 Location: Greece
| Re: Axial rr10
I have a bomber kit with 35t rc4wd and the motor gets pretty hot with stock gears.I want more speed but I want to stay brushed for know.I run 3s with hw 1060 brushed esc,I know not the best but does the job.Is the traxxas 21t titan good choice for more speed?Will I need a change in gearing?One more question,do yeti spurs fit on rr10?Here some pictures of my bomber. |
01-01-2017, 09:20 AM | #1319 |
| Re: Axial rr10
06-10-2018, 08:06 AM | #1320 | |
Newbie Join Date: Jan 2018 Location: Newberg
Axial rr10 - Similar Threads | ||||
fun day at the (axial wraith rock race - scalers axial honcho - axial discovery) | gionata78 | Scale Videos! | 1 | 08-06-2013 11:52 AM |
