Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: bilinvic's RR10 Bomber Build
Old 12-06-2015, 04:13 PM   #41
Default Re: bilinvic's RR10 Bomber Build
Why do all 4 rear shocks have Springs?
fr8cture is offline   Reply With Quote
Old 12-06-2015, 04:19 PM   #42
Originally Posted by bilinvic View Post
I'm thinking of putting 550 sized motor in mine after it arrives. But looking at this picture I'm thinking it might not fit actually. What are your thoughts? Would 550 motor get enough clearance with respect to the transfer case?
omikr0n is offline   Reply With Quote
Old 12-06-2015, 04:22 PM   #43
I'm positive a 550 can will fit fine.
I'm still playing with the shock settings...the springs still might be removed and I would refill the shocks with a higher viscosity shock fluid to compensate.
bilinvic is offline   Reply With Quote
Old 12-06-2015, 04:25 PM   #44
Need some dual front shock action. Lol
Old 12-06-2015, 04:27 PM   #45
I have thought about it, but I want this machine to crawl and quad shocks up front would be way too stiff IMHO.
Old 12-06-2015, 05:16 PM   #46
Is that motor mount plate a wraith or yeti? Assuming its yeti?
Sent from my iPad using Tapatalk HD
Biomedchad is offline   Reply With Quote
Old 12-06-2015, 05:19 PM   #47
Yeti
STRC CNC Machined Aluminum Center Motor Mount and Motor Cam Combo (Gun Metal) Yeti
Old 12-06-2015, 05:38 PM   #48
With the springs off on the rear RC4WD 100mm King shocks. Better?
I filled the springless shocks with 55w silicone shock fluid and I'm pretty sure the sprung rear shocks are 40w silicone shock fluid. I used a Proline short course Powerstroke front spring (green spring rate) with a stock King SC blue spring and the combo feels damned near perfect. I'll find out during the shakedown test.
RR10_Bomber_30
RR10_Bomber_29
Old 12-06-2015, 05:40 PM   #49
I think it looks better without the springs.
mikebecher is offline   Reply With Quote
Old 12-06-2015, 05:45 PM   #50
For now, I will using a brand new set of Axial BF Goodrich Krawler™ T/AŽ KX 2.2 Tires R35 on new Axial 2.2 Trail Ready HD Series Beadlock w/Slim Ring - IFD™ Wheels; Black. They are stuffed with Crawler Innovations Double Deuce foams. I want lightweight wheels and tires to minimize any additional drivetrain stress. The RC Bros knuckle weights provide the additional weight up front. I would like to use the stock Baja T/A KR2 tires and rims, but a SLW hub is required for the knuckle weight system. I used VP .725 SLW hubs up front and the stock plastic Axial (Long) 12mm Hex hubs out back (only until I get another pair of the VP .725s).
Old 12-06-2015, 05:46 PM   #51
I completely agree!
Old 12-06-2015, 06:07 PM   #52
The way it's suppose to be.
Old 12-06-2015, 06:12 PM   #53
Thank you fr8cture. Just doing some shop floor testing and the torque twist is 99% gone....no sway bar required.
Old 12-06-2015, 06:14 PM   #54
Yeah I figured it would. I would get a sway bar myself just for the scale look.
Old 12-06-2015, 06:23 PM   #55
Looking awesome. Yours is the best build I've seen yet.
GLHS592 is offline   Reply With Quote
Old 12-06-2015, 06:26 PM   #56
You read my mind again, I will get a sway bar for looks only; just not connected to each side.
Old 12-06-2015, 06:38 PM   #57
Looks great man. Does it need 725s to clear the knuckle weight system or is that personal preference? I just threw VP XD 795s on my Curries for my RR10 build and I had to step up to 600s but had more than enough clearance. I almost had it with 475s but had slight rubbing. 725s seem like they'd have a ton of tire scrub.
SCREAMER is offline   Reply With Quote
Old 12-06-2015, 08:30 PM   #58
Thanxs. I can get away with .600 hubs on regular wheels, but I want the option of adding a full weight circle if required without having to change the hubs out; the Axial Trail Ready B/L wheels don't have as much clearance in the back with the beadlock screws.
Old 12-06-2015, 08:38 PM   #59
Jus
Good stuff.
So the rear drive shaft is a Yeti MIP I assume? I so want to rob the center currie off one of my wraiths for my Bomber
Jus is offline   Reply With Quote
Old 12-06-2015, 11:07 PM   #60
Working on some of the scale details this evening.
Hobby Gear Fire Extinguisher w/ Yeah Racing cradle
Hobby Gear Jack
LEGO rope netting for the driver's net; Found this in my son's room. I'll have to go rummaging through is room tomorrow while he's at school to see if there's another for the passenger side...lol
RR10_Bomber_34
RR10_Bomber_31
Replaced the front remote shock reservoirs with solid aluminum stock. I drilled and tapped two holes on the backside to mount them identically as the plastic stock reservoirs were. Nothing replicates metal like real metal!!!!
RR10_Bomber_33
RR10_Bomber_32
bilinvic's RR10 Bomber Build - Similar Threads
Rr10 bomber available from tower jaykim5708 Axial RR10 Bomber 12 05-05-2016 07:28 PM
axial RR10 bomber new U4 class? Cork U4RC 2 01-15-2016 11:22 AM
New Axial RR10 Bomber available for pre-order! RPP Hobby RPP Hobby 0 11-09-2015 05:48 PM
