05-05-2017, 10:17 AM | #641 | |
RCC Addict Join Date: Aug 2005 Location: Oceano, CA
| Re: bilinvic's RR10 Bomber Build Quote:
05-05-2017, 04:22 PM | #642 |
Pics are always better My JK
05-05-2017, 09:47 PM | #643 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
All fixed up. Thank you guys for the info regarding the Wrangler MT/R tires....I have never seen asymmetrical tires NOT be directional before. Google was my friend finding pics of 1:1 MT/R tires mounted and sure enough, you guys are correct. My apologies to RC4WD, you guys did exactly what Goodyear intended. Last edited by bilinvic; 08-18-2017 at 10:53 PM. |
08-18-2017, 10:56 PM | #644 |
3 hours and 205 pics later, this whole thread from the beginning has been updated with working photos....once again FU PB Sadly, I haven't had the Bomber out lately...in fact, it's missing it's MMP ESC that I stole for my TRX4 build. I plan on replacing it sooner than later, I miss this awesome rig! |
08-19-2017, 05:54 AM | #645 |
RCC Addict Join Date: Aug 2008 Location: Paulina
Bless you Bill. Thanks for keeping the information and pics out there! Much appreciated.
08-19-2017, 05:58 AM | #646 |
Rock Crawler Join Date: Sep 2015 Location: Lake Stevens
^ No doubt ^ Thank you! Sent from my iPhone using Tapatalk Pro |
08-19-2017, 09:21 AM | #647 |
Pebble Pounder Join Date: Aug 2015 Location: Newfoundland
Love your rig build threads Bill! An inspiration to many of us and the information and photos included are invaluable! Sent from my iPad using Tapatalk |
08-19-2017, 04:41 PM | #648 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
177k+ views and 33 pages, that has to be a record for a build thread lol. How do you like those PL pro spec shocks and MT/R's? Like them better then hyrax tires? What is your favorite crawling tire? Since you basically own every tire available, lol. |
08-19-2017, 05:02 PM | #649 |
It is a pretty epic thread eh? Who wudda thunk!!! PL Pro Spec shocks have been great, no issues and no plans to replace them. I've only used the MT/Rs once and I was pretty impressed. I would have to say my favourite 2.2 tire is the Hyrax and for 1.9 it is KLRs. That being said, I still like to use various brands of tires to keep things interesting!!!! |
09-26-2017, 06:33 PM | #650 |
Pebble Pounder Join Date: Aug 2017 Location: Home
Hello. I need a bit of help on my Bomber suspension. I want it to be a high speed trail truck Currently running stock suspension but here's my build: RR10 Bomber 14/64 gearing Castle Sidewinder 3 with Vanguard 3150 motor XT60 connector Passive cooling: (2) Bastens aluminum heatsink Savox sw-1210sg (277.7oz/in, .15s) Castle 10A BEC enclosed in TRX receiver case Axial aluminum servo horn Axial 2spd kit with optional high speed gearing Traxxas 2075 shifting servo (125oz/in, .17s) Stock suspension geometry Stock King shocks/springs Stock oil Axial "soft" Rear sway bar Removed rear spare tire and housing Slipper clutch 1/2 turn out Proline 2.2 Hyrax G8 compound tires Proline stock open cell foams Front: Proline 2.2 Denali wheels Rear: Proline 2.2 Faultline wheels 1oz Beef Tubes Beef Patties per front wheel Traxxas thick gray wheel hexes in rear wheels 1oz lead weight on top of steering servo 1oz wrapped around each end of front axle 1.25oz wrapped around each end of rear axle Tactic TTX300 transmitter Energizer Ultimate Lithium in transmitter Steering dual rate: reduced by 2 notches Sidewinder ESC Setting: 1.Forward/brake/Reverse, 2.Brakes 50%, 3.Reverse speed 75%, 4.Punch control level 1.High, 5.Drag brake 10%, 6.Dead Band Normal(.1ms), 7.Voltage cutoff Auto, 8.Motor timing Low(0 degrees), 9.Motor type Brushless Gens Ace 3s 5000mah 50c "short" pack XT60 Front/Rear Ride Height: 1.73"/1.89" (measured at pumping to ground) Front/Rear track width: 11.25"/11.4" GPS'd Top speed: 13.5mph/27.5mph Theoretical Top Speed: 12.62mph/27.14mph Calculated Motor Power: 945 watts (1.3hp) Calculated Axle Torque: 8.69/4.04ft-lbs Rollout: .35:1/.76:1 So it's quite fast at 27.5mph. I like the stock foams in my Hyrax 2.2's. I have a set of the PL dual stage but I like the grip the stock foams provide. My issue is 1. The rear end kicks up (like a donkey kick) when going over bumps at speed and sometimes it'll just front flip 2. Rollovers are terrible. I know it's a solid axle and there's a compromise that comes with it but I'm sure there's a way to tune it. Will I need to upgrade my stock "King shocks" and springs or will I just have to tune the oil? |
10-02-2017, 12:18 PM | #651 | |
Rock Stacker Join Date: Feb 2016 Location: Mercia, UK
If you slide the little rubber bump stops part way up the damper shaft and run the Bomber over a problem ridge the rubber bump stops should be pushed back to touch the spring seats...if not then my other theory applies - too much compression damping at the rear so you will need to reduce the oil viscosity or change for damper pistons with softer damping characteristics. Are you using stock spring rates? | |
10-02-2017, 02:36 PM | #652 | |
I also just changed the front springs today to the stiffer 2.85lb/in green springs. I couldn't find the 2.47lb/in so I went with the stiffer ones. I put 40wt oil in there and while it helps me not rollover as much it seems to not take the bumps as well as before. I wonder if I should drop down to the 2.07lb/in springs and put 35wt oil in there instead. To help out some I also lowered my top speed on hi to ~24mph on a full charge. Read 23.6mph on GPS but wasn't fully charged. That should help with high speed handling too. I had to tear it down and change the gears to the 1.08 ratio in high gear. Last edited by DeathVirus; 10-02-2017 at 02:39 PM. | |
10-02-2017, 07:56 PM | #653 |
I don't run my crawler rigs for "high speeds" and therefore don't have a lot of advice for you. InterpidMercians' info will hopefully be helpful to you. Perhaps a stiffer sway bar would help with rollovers as well.
10-06-2017, 04:04 PM | #654 | |
I intend to use stiff springs in the rear because the torque twist is horrid on the Bomber. Even with the Axial "soft" rear sway bar it's still quite nasty | |
10-06-2017, 04:44 PM | #655 |
IIRC, this Bomber build runs regular Wraith length links. Not the trailing arms of the Bomber, short Twin Hammers, or mid length Wraith ones. The links are best for crawling and the TAs are for speed. @bilinvic has a bad assed only eclipsed by his bad assed picturesque locale. Super jealous of that and the high grip rocks. |
10-09-2017, 10:51 AM | #656 | ||
10-09-2017, 11:33 AM | #657 |
| bilinvic's RR10 Bomber Build |
10-10-2017, 08:48 PM | #658 |
I'm trying to figure out what NostopinlucR's rig is. It almost looks like a rock crawler like a Gmade or Rc4wd with a body attacked to it
10-10-2017, 08:58 PM | #659 |
| Re: bilinvic's RR10 Bomber Build |
10-11-2017, 02:50 PM | #660 |
bilinvic's RR10 Bomber Build - Similar Threads | ||||
Rr10 bomber available from tower | jaykim5708 | Axial RR10 Bomber | 12 | 05-05-2016 07:28 PM |
axial RR10 bomber new U4 class? | Cork | U4RC | 2 | 01-15-2016 11:22 AM |
New Axial RR10 Bomber available for pre-order! | RPP Hobby | RPP Hobby | 0 | 11-09-2015 05:48 PM |
