10-12-2017, 12:59 PM | #661 |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
| Re: bilinvic's RR10 Bomber Build Quote: Could I trouble you for an update on those tires? Thanks. Love the build as usual. Im looking to build a bomber for the same purposes as you have. Im probably going to keep the stock axles for now due to cost, but I want to give the dlux truss a shot. |
10-12-2017, 08:47 PM | #662 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
Sorry Motorider, I haven't had these tires out since. Hopefully soon, it pains me that I don't get out crawling as often as I would like. |
10-12-2017, 09:32 PM | #663 | |
Pebble Pounder Join Date: Aug 2017 Location: Home
1. Vastly reduces torque twist. The gear reduction makes it easier for the motor to transmit the power straight to the wheels instead of converting to torque twist 2. Increases drag brake effect- again, the gear reduction allows for a greater drag brake effect 3. Longer crawling running time- due to the higher gear ratio there's less drivetrain stress and therefore longer run times There's a reason for everything. I myself run the 2 speed with a sensorless motor and it runs great | |
10-15-2017, 07:12 AM | #664 |
Rock Stacker Join Date: Nov 2016 Location: Fenton
For front shocks are you using front or rear pro spec shocks? Sent from my SM-G920V using Tapatalk |
10-15-2017, 07:23 AM | #665 |
| Re: bilinvic's RR10 Bomber Build |
10-15-2017, 11:38 AM | #666 |
10-15-2017, 12:06 PM | #667 |
Monster truck tires are not made for technical rock crawling.
10-17-2017, 01:28 PM | #668 |
10-29-2017, 07:46 PM | #669 |
Great run today with the Bomber, it's been a long time since I've run this machine. Performance was outstanding with the 2.2 Goodyear MT/R tires today on both dry and slick rock. My friend's 2.2 Hyrax tires accomplished some pretty awesome lines today and the MT/Rs were able to match the performance easily. Bent both the driver's side front and rear axle stubs though...had a couple long barrel rolls down some rock faces today which was likely the cause. |
10-29-2017, 09:48 PM | #670 |
Looking awesome as always, Bill! Speaking of axles, which brand are the ones bending on you? Still at the build stage of mine... |
10-30-2017, 12:08 AM | #671 |
Thanxs durok. The front axle stub that bent is from Incision and the bent rear axle stub was an Axial part. I have spares and they are good to go now. I cringe when my trucks take some massive tumbles, but that is all part of the hobby!
11-28-2017, 07:49 AM | #672 |
RCC Addict Join Date: Jun 2017 Location: Canada
Hi I have a question about page 2 on your thread, how did you mount the rc4wd fuel cell? I really like the look and finish of aluminium and it's smaller size. I painted my stock fuel cell but i can already see the paint won't last very long on the trail... Sent from my Nexus 6 using Tapatalk |
11-28-2017, 09:33 PM | #673 |
I drilled and tapped a hole on each side of the fuel cell and used spacers and longer bolts to screw into the fuel cell. On the front, I used a clamp that is included in the Axial Universal 5 Bucket Light Bar Set.
11-29-2017, 12:03 AM | #674 | |
Im saving it for later just in case. It's a shame nobody makes an aluminium replica of the stock fuel cell. Sent from my Nexus 6 using Tapatalk | |
12-11-2017, 12:58 PM | #675 |
Newbie Join Date: Jan 2016 Location: Huntsville
Bill...I think you've tried more tires on the Bomber than most of us will ever use in a life time If you had to narrow it down to just two (cause I'm guessing one would be Hyrax), what tires are your favorite on the Bomber?
12-11-2017, 01:24 PM | #676 |
There are no more perfect wheels for the stock Bomber scheme. I just wish they worked with Proline tires without buying an extra inner ring.
12-11-2017, 01:37 PM | #677 | |
I have multiple sets of 2.2 SSD wheels wrapped with P-L tires using the regular black rings without any hassles. | |
12-11-2017, 01:40 PM | #678 | |
Good to know. SSD recommends not using their wheels with Proline tires unless you buy the inner ring. You might have convinced me to buy a set. I just checked and it appears SSD offers most, if not all, of their wheels with the Proline inner rings so you no longer have to buy them separately. Oddly, the Rock Racers are not offered in the Proline option so in that case you would have to buy the Proline inner rings separately if you so desire. Last edited by JatoTheRipper; 12-11-2017 at 01:47 PM. | |
01-31-2018, 10:55 PM | #679 |
For so long I have been using the stock glossy RTR interior which has always been on my to-do list to get it dulled down! I donated the glossy interior to my 10.2 SR5 Truggy and bought a new interior for the Bomber. I also picked up a sheet of Freqeskinz Bomber interior skinz from AMain. I painted the backside PS-5 black and dullcoated the topside with PS-55 flat clear. I'm very happy with how it turned out although it took close to two hours to apply the decals. You definitely need a heat gun to get them to contour to the fairly complex interior convex and concave surfaces. |
01-31-2018, 11:16 PM | #680 |
Came out fantastic, man! Every time I looked a their site I've wondered at how tricky application might be... The MT/Rs are lookin' sweet on those silver SSD wheels... a prime example of a hot-rodded Bomber, for sure! |
bilinvic's RR10 Bomber Build - Similar Threads | ||||
Rr10 bomber available from tower | jaykim5708 | Axial RR10 Bomber | 12 | 05-05-2016 07:28 PM |
axial RR10 bomber new U4 class? | Cork | U4RC | 2 | 01-15-2016 11:22 AM |
New Axial RR10 Bomber available for pre-order! | RPP Hobby | RPP Hobby | 0 | 11-09-2015 05:48 PM |
