![]() | #701 |
Pebble Pounder Join Date: Aug 2017 Location: Home
Bilinvic what is your track width front/rear?
![]() | #702 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
With the Pitbull RBII tires, track width is 295mm (11.6"). I'm using the slightly wider SSD hubs with the integrated brake discs.
![]() | #703 |
![]() | #704 |
I wanna be Dave ![]() Join Date: Oct 2012 Location: Medina
Awesome looking Bomber bilinvic! Seems very sorted as well! Can I ask what you used to create the dry-break for your "fuel" filler?
![]() | #705 |
Thank you mewalsh100. Check out post #589 for info on the dry-break filler. bilinvic's RR10 Bomber Build |
![]() | #706 | |
| ![]() Quote:
Front springs are P-L SC blue stripe and the rears are yellow stripe. | |
![]() | #707 |
Newbie Join Date: Aug 2017 Location: The Netherlands
Hello, I have a Bomber kit that i am going to build as soon as the electronics are coming in. I will use the Bomber mainly for creeping/crawling. I would like to have youre advise on the rear shock set-up. I would like the stock king shocks in the original place with a set of extra shocks/dampers behind them. What shock length do i need? Can i use internal spring shocks without the springs for dampening only? What shock oil weight should i use for both shocks? Will this eliminate torque twist? Should i use the swaybar? If i don’t need the swaybar anymore how will i mount it just for scale looks? Thank you |
![]() | #708 |
Quarry Creeper Join Date: Jul 2017 Location: Sweden
![]() | #709 |
![]() | #710 | |
| ![]() Quote: | |
![]() | #711 |
Newbie Join Date: Dec 2018 Location: Columbia Falls
Great build! I just read pretty much the whole thread. A lot of great information and you answered a lot of questions for me. I even started taking notes. Lol I got a Bomber for Christmas and I am ready to tear into it. Thanks for all the info.
![]() | #712 |
Newbie Join Date: Jun 2016 Location: so cal
Im not sure if it has been said in the thread or if its still alive but ive got to page 15 or so and havent found anything yet, but what are you using for the rear bump stops?
![]() | #713 |
Newbie Join Date: Apr 2020 Location: Norway
First off, great build. Edit: Read through the thread again and found my answer, cheers. Best Regards. Last edited by Trep; 04-26-2020 at 01:54 PM. |
Rr10 bomber available from tower | jaykim5708 | Axial RR10 Bomber | 12 | 05-05-2016 07:28 PM |
axial RR10 bomber new U4 class? | Cork | U4RC | 2 | 01-15-2016 11:22 AM |
New Axial RR10 Bomber available for pre-order! | RPP Hobby | RPP Hobby | 0 | 11-09-2015 05:48 PM |
