Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: bilinvic's RR10 Bomber Build
Old 12-07-2015, 05:39 AM   #61
Default Re: bilinvic's RR10 Bomber Build
Nice work on those aluminum reservoirs
youngblood is offline   Reply With Quote
Old 12-07-2015, 06:11 AM   #62
Been looking at those hubs but vp doesn't sell the 4 40 kit anymore. Is there a different vendor selling these or can I get some dimensions. Thanks
Biomedchad is offline   Reply With Quote
Old 12-07-2015, 08:19 AM   #63
I used Locked Up RC scale wheels studs:
Locked Up RC 4-40 Acorn Nut Wheel Studs (2
bilinvic is offline   Reply With Quote
Old 12-07-2015, 09:04 AM   #64
Im Brandon
Brandon's Avatar
You installed longer shocks correct? Most likely why you aren't running into any clearance issues at full compression.
Build looks great
Originally Posted by bilinvic View Post
Regarding the center rear axle and MIP driveshaft, here are some pics with the rear suspension compressed.
1. With the driver's side compressed. It's hard to tell the driveshaft is clearing the spur cover, but you can clearly see light between the shaft and housing.
2. With the passenger side compressed. There's approximately 3mm of clearance.
3. With both sides fully compressed. Note: I did add a rubber bump-stop so that the top of the SSD link mount wouldn't travel beyond the chassis underneath the fuel cell.
Brandon is offline   Reply With Quote
Old 12-07-2015, 09:43 AM   #65
Build looks great
Good point, they are slightly longer. Thank you.
Old 12-07-2015, 01:54 PM   #66
X2!^^^^^
What does the rig weigh?
sic1to is offline   Reply With Quote
Old 12-07-2015, 02:36 PM   #67
More details added:
Fuel Cell Supply Tube
RC4WD Baja Designs Squardon LED Pods
A secret bottle of NOS (in front of fuel cell)
At this point, my Bomber weighs in @ 7 lbs 10.5 oz w/o battery, 8 lbs 3.5 oz w/ 3300 mAh 3S battery.
RR10_Bomber_38
RR10_Bomber_37
RR10_Bomber_35
RR10_Bomber_36
Old 12-07-2015, 03:25 PM   #68
Im interested in hearing how the king shocks perform. Still deciding on shock conf
Old 12-07-2015, 06:44 PM   #69
Everyone is out of everything it seems. Can't find any of the 4-40 acorns for some vanquish hexs. Nuts
Old 12-07-2015, 06:53 PM   #70
Can someone give me a length of the 4-40 screws? I can get some from McMaster Carr until locked up or vanquish has the scale ones back in stock.
Old 12-07-2015, 10:42 PM   #71
Nice build, you always build the best, still going to check out Mt. Doug one of these days.
islrcr1 is offline   Reply With Quote
Old 12-08-2015, 02:38 AM   #72
that thing is badass, i so want one. how are those pod lights?
__T__ is offline   Reply With Quote
Old 12-08-2015, 07:04 AM   #73
Looks awesome dude. Nice details.
tedo is offline   Reply With Quote
Old 12-08-2015, 11:17 AM   #74
I like everything you have done to this rig. I'm going to copy some of it as I can. Those lights are exactly what I was looking for. Do you just plug them into the rx? Also, can you please update your parts list in the first post for us lazy people? ;)
GLHS592 is offline   Reply With Quote
Old 12-08-2015, 07:45 PM   #75
Thanxs guys.
The light pods work well, I have them on my DMG Wraith as well, they are 2S only. I haven't hooked them up on the RR10 yet, on the Wraith I use a seprate 2S LIPO for the pods and lightbar. I may just use the RX since my BEC is set to around 8 volts for my HH servo.
I would also like to pick up a KoH rear lightbar.
I'll work on getting a full parts list posted soon.
Old 12-08-2015, 08:06 PM   #76
Looks awesome! Your build threads never disappoint!
Terrible1 is offline   Reply With Quote
Old 12-08-2015, 08:52 PM   #77
Wow. Great job on the custom and upgraded parts. So very unique, something to be proud of. Brovo........
luckster is offline   Reply With Quote
Old 12-08-2015, 09:02 PM   #78
Build specs to date: (Copied and pasted from a Word Table)
Vehicle Build Specs: RR10 Bomber
Base Vehicle: Axial RR10 Bomber RTR
Front Axle:
Housing - SSD Diamond Axle; Black
Link Mount / Truss - SSD Diamond Front Axle Upper Link Mount; Grey
Servo Mount - Axial; Stock RR10 Bomber; Reversed
Diff Cover - SSD Diamond Axle; Black
Bearing Caps - n/a (3rd Member)
C-Hubs - Vanquish; Anodized Orange
Knuckles - Vanquish: Anodized Orange
Knuckle Bushings - Vanquish
Gears - Axial HD Bevel 38T/13T
Axle Shafts - VP VVD V1-HD 4mm Stubs
Locker - Grip Fab SS
Steering Links - SSD Titanium Steering Links for AR60 Axle
Rear Axle:
Link Mount / Truss - n/a
Lockouts - SSD; Black
Gears - Axial HD Bevel 43T/13T
Axle Shafts - SSD
Locker - Grib Fab SS
Misc. - SSD Diamond Axle Skids; Front & Rear
Transmission:
Case - Axial; Stock RR10 Bomber
Motor Plate - STRC CNC Machined Aluminum; Gunmetal
Internal Gears - Axial; Stock
Pinion Gear - Robinson Racing 10T 32P
Spur Gear - Axial 64T 32P
Top Shaft - Axial; Stock RR10 Bomber
Intermediate Shaft(s) - Axial; Stock RR10 Bomber
Outputs - Axial; Stock RR10 Bomber
Transfer Case - Axial; Stock RR10 Bomber
Drive Shafts - MIP Yeti Rear; Junfac Universal; 120-155mm
Slipper - Axial; Stock RR10 Bomber
Chassis / Suspension:
Frame - Axial; Stock RR10 Bomber
Skid Plate - Axial; Stock RR10 Bomber
Cross Members - n/a
Cross Members - n/a
Front Bumper - Axial; Stock RR10 Bomber
Rear Bumper - n/a
Rock Sliders - n/a
Chassis Modifications - n/a
Shock Mounts - Vanquish; Grey (Axle Mounted)
Body Mounts - Axial; Stock RR10 Bomber
Shocks - RC4WD King Short Course; Slash Rear (110mm)
Shock Fluid - Factory Team; 40w Front/Rear; 55w Quad Rear
Upper Front Links - Vanquish Titanium; Wraith
Lower Front Links - Vanquish Titanium; Wraith
Upper Rear Links - Blue Monkey RC Wraith TA; Ti; Jato Link Ends
Lower Rear Links - Blue Monkey RC; Wraith; Revo Link Ends
Link Ends - Traxxas Revo & Jato
Battery Mount - Axial; Stock RR10 Bomber
1. Misc. - RC4WD King Dual Spring Shock; (120mm) Quad
2. Misc. - RC Bros Knuckle Weight Kit
Electronics:
Motor - Holmes Hobbies TrailMaster BL Pro 540 - 3100kv WP
ESC - Castle Creations; Mamba Max Pro WP
Sensor Cable - Novak
Servo - Holmes Hobbies BLS HV400
Lighting - RC4WD Baja Designs Squadron Set
BEC - Castle Creations; 10-Amp
Receiver - Spektrum
Radio - Spektrum DX4S
Battery - Various 3S
Wiring Connectors - Traxxas
Misc. - Racer's Edge Aluminum Pro Servo Horn; 25T
Rolling Stock:
Wheels - Axial 2.2 Trail Ready HD BL IFD™ Wheels; Black
Beadlock Rings - n/a
Hubs / Offset - Vanquish; .725
Hex - Axial 12mm Aluminum
Hex Pins - Axial
Wheel Nuts - Locked Up RC 4-40 Acorn Nut Wheel Studs
Scale Hubs - n/a
Tires - Axial BFGOODRICH KRAWLER™ T/AŽ KX 2.2 TIRES R35
Tire Foams - Crawler Innovations Double Deuce
Body / Interior:
Body - Axial; Stock Bomber Fabrications
Paint / Graphics - Axial; Stock Bomber Fabrications
Interior Base - Axial; Stock RR10 Bomber
Figure(s) - Axial; Stock RR10 Bomber
Seat(s) - Axial; Stock RR10 Bomber
Interior Details - “Lego” Driver’s Window Net
1. Exterior Details - Hobby Gear 1/10 Extinguisher / Jack; RC4WD Fuel Cell
2. Exterior Details - Custom Fuel Filler, Custom Shock Reservoirs
General:
Bearings - Axial; Fast Eddy
Hardware - Stainless Steel
Grease - Castrol Pyroplex Blue
Waterproofing - MG Chemicals Urethane Conformal Coating
Misc. - Yeah Racing Extinguisher Mount
Misc. - Yeah Racing NOS Machined Aluminum Bottle
Old 12-09-2015, 11:13 AM   #79
I dropped the pinion down to a Robinson Racing 10T....12T / 64T was just too fast; believe it or not! The 10T will also help the motor stay cooler. While I had the body off, I added a on/off switch on wires supplying power for the lighting from the RX.
Old 12-09-2015, 11:17 AM   #80
Beyond excellent build.
Looking forward to seeing running vids
cmbscx10 is offline   Reply With Quote
bilinvic's RR10 Bomber Build - Similar Threads
Rr10 bomber available from tower jaykim5708 Axial RR10 Bomber 12 05-05-2016 07:28 PM
axial RR10 bomber new U4 class? Cork U4RC 2 01-15-2016 11:22 AM
New Axial RR10 Bomber available for pre-order! RPP Hobby RPP Hobby 0 11-09-2015 05:48 PM
