Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: bilinvic's RR10 Bomber Build
Old 12-10-2015, 10:08 PM   #101
Default Re: bilinvic's RR10 Bomber Build
First off great build! Been watching from the beginning and am jealous that you've built exactly what I want to build already, mine is going at snail speed though An idea on the shocks; most Ultra 4 cars use the coilover as a coil carrier only, some have very light dampening, some don't. If your valving is too stiff from running 2 shocks, pull all the oil out of one and tune the other shock to handle dampening. There are literally thousands of ways to set it up and I've already started experimenting with my Bomber to get a good combo to mimic the 1:1 racers
generalee7 is offline   Reply With Quote
Old 12-10-2015, 10:34 PM   #102
Originally Posted by bilinvic View Post
I was thinking of converting the steering into a suicide set-up to mimic the 1:1. Would that mean my RR10's new name would be "Suicide Bomber"????
Great, now the NSA is sub'd. On second thought, they've probably been freaking out for a while about this RR10 Bomber. "What could it be, some sort of new ISIS terror plot? Will this lead up to the IR8 Bomber?"
mikebecher is offline   Reply With Quote
Old 12-10-2015, 11:34 PM   #103
Stop it,Stop it now or president TRUMP will stop us from using our VISA to get it to our doors!!!!
THUNDER PRO is offline   Reply With Quote
Old 12-11-2015, 06:00 AM   #104
What did u wrap your shock canisters with? That looks awesome!
AWraith build is offline   Reply With Quote
Old 12-11-2015, 09:21 AM   #105
The shock reservoirs were replaced with custom fabricated solid aluminum, drilled and tapped for mounting.
bilinvic is offline   Reply With Quote
Old 12-11-2015, 11:59 PM   #106
Did you see Bomber fab posted a pic of your build on Instagram?
Cheers Jacob
Bmxreeves is offline   Reply With Quote
Old 12-12-2015, 12:09 AM   #107
That's awesome. Randy Slawson texted me earlier asking about my Bomber! I couldn't believe it when his name showed up on my phone.
Old 12-13-2015, 07:54 AM   #108
Loving this build. Going to "Borrow" your reservoir idea. The farthest I have gotten with mine is removing it from the box lol.
Cheers,
Wade
Wade is offline   Reply With Quote
Old 12-14-2015, 12:42 AM   #109
So what length shocks did u end up all around? I saw earlier someone said you weren't having clearance issues with the centered axle but I thought I saw that you were running 110mm shocks which I thought was the same as stock?
photocycler is offline   Reply With Quote
Old 12-14-2015, 12:46 AM   #110
The primary sprung shocks are 110mm, the stock shocks measure in about 103mm.
Old 12-14-2015, 03:46 PM   #111
dbw
it certainly looks great, have you had it out yet? you have spent so much time with your modified trailing arm wraith on the trails and rocks i am anxious to hear what you have to say about this rig.
dbw is offline   Reply With Quote
Old 12-14-2015, 04:06 PM   #112
Thanxs. No, haven't tried 'er out yet, I'm waiting for more parts to arrive first. I am getting quite anxious though!
Old 12-14-2015, 04:48 PM   #113
Suspension mocked up now....
Blue Monkey RC Yeti trailing arms w/ Revo link ends
Blue Monkey RC Ti upper links w/Jato link ends
RC4WD King Off-Road Short Course 110mm Racing Shocks (Slash Rear) front & rear
RC4WD King Off-Road Dual Spring 120mm Shocks for the dual rear shock set-up
The shocks will require fine tuning once the machine is up and running for it's shake-down!
MIP Yeti rear driveshaft
Wheelbase is now 15 1/8" compared to the stock WB of 14.75"
Generally the second rear shock is a bypass shock (no springs). Of course yours could be for performance purposes.
Cork is offline   Reply With Quote
Old 12-14-2015, 10:19 PM   #114
Cork missed page 3, 4, and 5
SCREAMER is offline   Reply With Quote
Old 12-15-2015, 09:44 AM   #115
I saw those after I posted. looks better without the springs. Killer rig! I'm having some sleeves 3d printed that will mimic by-pass tubes They should be here by the end of the week. They'd really look nice on those.
Old 12-15-2015, 10:07 AM   #116
I'm curious to see what these "sleeves" look like.
Old 12-15-2015, 10:12 AM   #117
Yep, so am I. I should receive them by the end of the week. I don't know how to post pic.
Old 12-15-2015, 01:11 PM   #118
So no 2 speed with your setup.
Biomedchad is offline   Reply With Quote
Old 12-15-2015, 01:25 PM   #119
In my humble opinion, if you go brushless then a 2 speed is completely unnecessary. With my Holmes 2200kv I can still hit close to 20mph but have incredible low speed control. If I added 1 tooth to the pinion I could get over 20 easily. I also have the choice of using 4s if I want more speed. If you're looking for much more speed than that then you'd be building something low and fast that couldn't crawl anyway and a granny low gear would be useless. Any brushless motor you choose for your intended use will give you a lot of range at both ends of its limits.
Old 12-15-2015, 01:30 PM   #120
Exactly what SCREAMER said, sensored brushless systems doesn't require a 2 speed IMHO. A sensored motor is the key to this equation though.
bilinvic's RR10 Bomber Build - Similar Threads
Rr10 bomber available from tower jaykim5708 Axial RR10 Bomber 12 05-05-2016 08:28 PM
axial RR10 bomber new U4 class? Cork U4RC 2 01-15-2016 12:22 PM
New Axial RR10 Bomber available for pre-order! RPP Hobby RPP Hobby 0 11-09-2015 06:48 PM
