![]() | #41 |
Quarry Creeper ![]() Join Date: Jun 2013 Location: Canada
| ![]() You will gain little or no speed with the 2 speed, what you are adding is a low gear giving slow speed control to faster brushless system. That shouldn't be needed at all on 30T brushed on 2S.
![]() | #42 |
RCC Addict Join Date: Aug 2013 Location: Missoula
Or you can gear low gear to where you are now and high will go considerably faster. I believe the gears are 1.08:1 and 2:1. Not going to be very nice for a slowish brushed motor though. Another option is to split down the middle, low gear will be lower than you are now, high gear will be higher. |
![]() | #43 |
Newbie Join Date: Jun 2016 Location: Germany
how would you control a 2 speed setup and an optional drag break switch for lo/hi? Guess one would need a a 4 channel radio and receiver for this and a ESC like the MMX that would allow this?
![]() | #44 |
Newbie Join Date: Dec 2008 Location: Grand Junction, CO/ Calgary, AB
![]() | #45 |
RCC Addict Join Date: Jun 2017 Location: Canada
Comes with the Bomber kit if im not mistaken Sent from my Nexus 6 using Tapatalk |
![]() | #46 |
I bought my bomber 2nd hand and installed the 2speed but now am dealing with mounting the servo to the stock skid/ intergy metal cage with no mount left on the skid.
![]() | #47 |
Check out RC Recycler or a local shop, they might have the kit 2-speed components? Sent from my Nexus 6 using Tapatalk |
![]() | #48 | |
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
| ![]() Quote:
Mamba Firmware V2.02 | |
![]() | #49 |
Quarry Creeper Join Date: Mar 2018 Location: Park Hills
Dito with binding issues. I got mine installed. Assembly was a breeze. I set my end points on my servo but even still it is just binding up. I really wish the shift fork rod didn't roll I did t not have a good servo horn or linkage to use. I'm using what I could find locally. Some smaller rod ends and a traxxas servo saver. Horizontally the throw is straight but my linkage goes up from the trans to the horn a little and I think it's causing bind. First I tried this, the traxxas servo saver, terrible angle, super bindy. ![]() Then I tried this, a regular servo arm. Close but still binds without assistance. ![]() ![]() Last edited by angrchair; 04-14-2018 at 08:38 PM. |
![]() | #50 | |
Quarry Creeper Join Date: Jul 2017 Location: Sweden
| ![]() Quote:
So, with a good brushless system and a Mamba X, you get kind of a 2-in-1 driving experience. When I build a bomber within a couple of months, this will definitively go into it from the start. | |
![]() | #51 |
Newbie Join Date: Apr 2018 Location: Ft Worth
One more thing on my list of things I want to do to my bomber.
![]() | #52 | |
Quarry Creeper Join Date: Aug 2015 Location: Worthington
| ![]() Quote:
![]() | #53 | |
| ![]() Quote:
1 - You need to set the endpoints so that the esc engages the rr/crawler mode and the drag brake to your linking. The diagrams linked off of this page can help. X-series Rock Race/Crawler Auxiliary Wire Mode 2 - connect the servo and adjust the servo horn, servo horn hole, and linkage length so that the transmission shifts properly. You may need a servo saver horn with additional holes closer to the axis, and a reverser module if your servo rotates opposite to what you need. There are reverser modules with integral y-harness for as little as US$10. | |
![]() | #54 |
Can you put the 2-speed + AUX wire on a 2-position switch or clicky button? Or does it have to be a dial type channel? I can't see how this can shift the transmission and change mode at the same time... Sent from my Nexus 6 using Tapatalk |
![]() | #55 |
| ![]() You will want 2 postitons for buttons/switch and set up servo to shift between high and low and y harness the signal to esc that you set up that tells it what mode to be in
![]() | #56 |
Someone needs to write a step by step guide for this... I feel like a moron everytime someone tries to explain. Sent from my Nexus 6 using Tapatalk |
![]() | #57 |
Newbie Join Date: Mar 2018 Location: Arvada
I totally agree with the step by step. I also need to find the part number for the 2 speed servo mount if anyone can help out! |
![]() | #58 |
Part #31323 Axial Racing - RR10 Electronics Box |
![]() | #59 |
![]() | #60 |
Quarry Creeper Join Date: Dec 2009 Location: Cape Cod
Axial rr10 | ptaryan654 | Axial RR10 Bomber | 1319 | 06-10-2018 08:06 AM |
RR10 Maiden voyage | skybolt | Axial RR10 Bomber | 1 | 12-17-2015 05:53 PM |
Trying out parts from the RR10 | Chiphead | Axial Yeti | 7 | 11-24-2015 11:01 AM |
Axial RR10?? | skybolt | Chit Chat | 12 | 11-09-2015 09:05 AM |
