Bomber tranny question Is the Bomber tranny the same as the Yeti tranny? I thought that I read it's the same tranny, but with a bomber specific transfer case. I just wanted to verify if they are the exact same tranny and transfer cases. Thanks in advance for your help! Sent from my iPhone using Tapatalk |
Re: Bomber tranny question Also do you have to have the complete kit to make it 2 speed what is in the trans now just high gear? Sent from my SM-G900V using Tapatalk |
Re: Bomber tranny question The output on the t case is longer than yeti comes stock in high gear. Axial 2 speed kit gives you a slightly higher high gear option. I have axial 2 speed and can't complain about it."thumbsup" |
Re: Bomber tranny question Yes, The Bomber just has a extended out put for the transfer case. It comes with high gear installed. I bought the Axial conversion. It give you the option of stock high gear or a slightly overdriven high gear. I used the over driven high gears. http://i64.tinypic.com/n13028.jpg |
Re: Bomber tranny question Comparing the instructions for both the Bomber & Yeti share a lot of tranny parts Motor mount AX31106 Spur cover AX31107 Trans case AX31108 Btm shaft AX31129 Top shaft AX31127 and all trans gears where they differ your right is the transfer case Yeti has parts off AX31108 Bomber has it's own AX31324 & the output shafts are different yeti (short) AX31134 Bomber (long) AX31313 |
Re: Bomber tranny question Quote:
Also, the Bomber long output shaft part# is AX31313. The Bomber manual shows it as part# AX31312, which is the part # for the RTR stock motor. Thanks for the detailed info, I appreciate it! "thumbsup" |
Re: Bomber tranny question Oops yep, that's a typo, your right AX31313 for the bomber output shaft |
Re: Bomber tranny question So will a yeti tranny in a bomber with the 2 speed still work with the interior. |
The Yeti tranny and the Bomber tranny are the same. The difference is the transfer case. The Bomber has a different transfer case housing and a longer output shaft (in the transfer case). Yes, the 2 speed conversion will work with the interior panel installed. Sent from my iPhone using Tapatalk |
Re: Bomber tranny question |
