01-08-2016, 07:21 AM | #21 |
Pebble Pounder Join Date: Jan 2014 Location: Chester, WV
| Re: Wheelbyte's RR10 Bomber
Where did you find the Power Stroke XT's at? I'm having a hard time finding any in stock anywhere... Thanks
01-08-2016, 07:57 AM | #22 | |
Quarry Creeper Join Date: Feb 2015 Location: Florida
| Re: Wheelbyte's RR10 Bomber Quote:
01-08-2016, 08:06 AM | #23 | |
| Re: Wheelbyte's RR10 Bomber Quote: Thanks so much man. They must have just got some in stock because I have been checking!!!!! | |
01-15-2016, 09:52 AM | #24 |
Pebble Pounder Join Date: Jun 2013 Location: Morgan Hill
Got a set of the clear Axial body panels.... I had preordered them from Tower, I should have ordered two sets as I see they are now back ordered until late Feb. Ended up shooting them with Pactra Indy Silver backed with white. |
01-15-2016, 10:51 AM | #25 |
Rock Crawler Join Date: Apr 2006 Location: Folsom, CA
That looks great!
01-15-2016, 11:21 AM | #26 |
Damn, i was planning the exact same thing for my aluminum panels. Lol. My kit is on the way. Oh well. Looks really good, like I thought it would. Haha
01-15-2016, 11:47 PM | #27 |
Rock Stacker Join Date: Dec 2015 Location: Yucaipa
| Re: Wheelbyte's RR10 Bomber That looks awesome! Great job! Sent from my iPhone using Tapatalk |
01-18-2016, 12:06 PM | #28 |
| Re: Wheelbyte's RR10 Bomber Thanks!! Finally got a hold of a Vanquish Currie Antirock swaybar.... seems like they were out of stock forever. Made some shorter links for it everything else fit perfect.... no rubbing whatsoever at full compression! Now hopefully Vanquish can release the Currie F9's soon!!! |
01-18-2016, 11:24 PM | #29 |
Newbie Join Date: Dec 2015 Location: Athens
How stiff of a spring are you running on the sway bar? Sent from my iPhone using Tapatalk |
01-19-2016, 08:53 AM | #30 |
| Re: Wheelbyte's RR10 Bomber I am running the spring that comes with the Vanquish bar...... right now I am running the link in the last hole on the arm which is the softest setting...... that is how you adjust the stiffness by moving where the link attaches.
01-20-2016, 02:38 AM | #31 |
Newbie Join Date: Nov 2004
How are those links?
01-20-2016, 12:24 PM | #32 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
Thought you were running our panels at first. Your rig is looking good. |
01-20-2016, 08:31 PM | #33 |
| Re: Wheelbyte's RR10 Bomber |
01-20-2016, 08:57 PM | #34 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Ya, he's got an exo light bar under the roof.
01-20-2016, 09:54 PM | #35 |
Quarry Creeper Join Date: Jan 2009 Location: Cerritos
Looking good!
01-21-2016, 04:34 PM | #36 |
01-28-2016, 12:00 PM | #37 |
Did a little more work on my Bomber..... got a radiator painted up and installed. Also installed a 1 inch VP lightbar in the front bumper. I am using a HeyOk dimmable lighting controller running off the 3rd channel so there are 3 levels for brightness. Also getting together the pieces together in hopes the VP Currie F9's will be available soon so I can build some new axles. HD gears underdrive rear, FI spools and VP VVD's along with VP clamping hexes. Probablly going to go with the scale chubs and knuckles. Does anyone if there is a huge difference pros/cons in the zero ackermann steering or ackermann racing on the stage 1 knuckles vs the scale knuckles steering? Last edited by wheelbyte; 01-28-2016 at 09:35 PM. |
01-28-2016, 12:14 PM | #38 | |
01-28-2016, 12:16 PM | #39 |
Also how do you like the light bar in the front bumper? How bright is it? And can you still hold the truck with your fingers through the bumper? I find its pretty convenient and comfortable to hold by the bumper and would hate to lose that feature if I installed the same bar there.
01-28-2016, 01:29 PM | #40 | |
Tags |
bomber, koh, rr10 |
Wheelbyte's RR10 Bomber - Similar Threads | ||||
bilinvic's RR10 Bomber Build | bilinvic | Axial RR10 Bomber | 712 | 04-25-2020 08:09 AM |
Rr10 bomber available from tower | jaykim5708 | Axial RR10 Bomber | 12 | 05-05-2016 07:28 PM |
Bomber RR10 parts | Erik D_lux | Axles, Trannys, T-case | 3 | 12-16-2015 07:17 AM |
