Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: My Bomber build
Old 12-27-2015, 10:55 AM   #1
Default My Bomber build
Let me k ow what you think
Sent from my XT1254 using Tapatalk
bredmx is offline   Reply With Quote
Old 12-27-2015, 11:16 AM   #2
Default Re: My Bomber build
Great build! I'm liking those SSD axles more and more now...
generalee7 is offline   Reply With Quote
Old 12-27-2015, 06:15 PM   #3
Do the ssd housing have more ground clearance then the stock ar60?
Crazysammi87 is offline   Reply With Quote
Old 12-27-2015, 06:43 PM   #4
They are about the same. You can use a bigger tire and gain more clearance.
Old 12-27-2015, 08:01 PM   #5
So,let's see that winch set up.
THUNDER PRO is offline   Reply With Quote
Old 12-27-2015, 08:04 PM   #6
It's just for show at the moment. Lol. Waiting on winch plate.
Old 12-27-2015, 09:53 PM   #7
You having any interference issues with he centered ssd rear?
godwnlo is offline   Reply With Quote
Old 12-27-2015, 11:32 PM   #8
When the rear end is fully compresses it hits a little but not noticeable. I run the sway bar so that helps with flex and compression of the shocks. DMG Bumper and trans adapter plate
Old 12-28-2015, 11:51 AM   #9
Ok that's what I was thinking it would be. I was looking at the same set up
My Bomber build - Similar Threads
bilinvic's RR10 Bomber Build bilinvic Axial RR10 Bomber 712 04-25-2020 08:09 AM
Maslin's Bomber Not-Ready-To-Run Build maslin Axial RR10 Bomber 192 05-04-2018 05:08 PM
Rottenbellys bolt on bomber build. rottenbelly Axial RR10 Bomber 59 12-13-2016 02:30 PM
Forestbumpr's RR10 Bomber Build forestbumpr Axial RR10 Bomber 29 12-28-2015 09:12 PM
Stealth bomber the Class 3 build RockChuck 2.2 Scale Rigs 53 05-04-2015 07:15 PM
