04-04-2016, 01:00 PM | #21 |
Rock Stacker Join Date: Feb 2016 Location: Under Your Hood
| Re: Budget upgrade for axles?
Whats everyone using for the rear axle, besides the stock Axial shafts..
04-04-2016, 01:25 PM | #22 |
Quarry Creeper Join Date: Dec 2009 Location: Cape Cod
I built mine with dlux housings, brass beef tubes, Axial UD gears, LURC FI Spools, Axial universals in front. I am still running the plastic lockouts in the rear and chubs/knuckles in front. I started out with beef tubes in the front only to save a few bucks but quickly broke a rear housing, then had to spend $20 on a housing and $20 on rear shafts. I recently installed the new VP one piece servo mount, definitely worth $12 over the factory bendy plastic unit. At a minimum I would do beef tubes (front and rear, probably steel for thread durability if I were doing them again) and shim the stock pinion gearing to extend gear life. I would also recommend the VP one piece servo mount, a real steering servo, and some non plastic steering links. I am running the brass beef tubes front and rear without issues. I would assume the brass would be easier to strip the threads on, so be careful not to overtighten the chub and lockout screws. I haven't noticed this on mine yet, probably 20 hours of use on them now. I am still running brushed power (Titan 21T). If I damage these I will try the budget friendly Incision units as those are nicely made and seem to work well on my Yeti. |
04-04-2016, 01:27 PM | #23 |
| Re: Budget upgrade for axles? |
Budget upgrade for axles? - Similar Threads | ||||
upgrade axles??? | R/C BUM | Losi Micro-Rock Crawler | 4 | 08-28-2010 07:46 PM |
Budget Chassis/Axles for a 2.2 Scaler? | alexchen86 | 2.2 Scale Rigs | 4 | 07-17-2010 08:42 PM |
anyone upgrade to 5mm axles | doomdog666 | General Crawlers | 3 | 04-10-2008 12:50 PM |
Need help finding tlt axles on a budget | stack'o'rocks | Newbie General | 6 | 06-06-2007 04:41 PM |
