01-31-2016, 01:59 PM | #1 |
Rock Stacker Join Date: Aug 2011 Location: fremont
| Steering servo mount options?
IV noticed a ton of flex coming from the stock servo mount now that I upgraded to VP steering links, so what are my options here? I've looked and can't seem to find any bomber specific pieces?
01-31-2016, 02:45 PM | #2 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Steering servo mount options?
I think the bomber servo plate is plastic right? If so, pick up a wraith/spawn servo plate which is aluminum and pick up some aluminum servo mounts as well.
02-04-2016, 09:39 PM | #3 |
Rock Stacker Join Date: Jan 2016 Location: US
Anybody having issues with the servo itself? The stock didn't last long. I expected that. But I have upgraded to a Spektrum S6230 and have just shelled it out for the second time without any real abuse. Did I just make a bad choice in servos? Or are you all having issues too? Sent from my SAMSUNG-SGH-I337 using Tapatalk |
02-04-2016, 09:55 PM | #4 | |
Rock Crawler Join Date: Aug 2015 Location: Big Island
| Re: Steering servo mount options? Quote:
02-04-2016, 10:52 PM | #5 |
I'm loving the Promodeler servo on my go fast Bomber. It's strong, quiet, and well made. I'd love to try the new Holmes as well just need to catch one in stock. Dewey, for the servo mount, just pick up a Wraith servo plate and some aluminum servo mounts and clamps and you'll be flex free in no time. |
02-05-2016, 06:48 AM | #6 |
I actually like the one piece design, not so much with the flexy plastic. Someone will copy the stock mount in aluminum soon enough. It will probably be Boom Racing or a similar company but I'll try it.
02-05-2016, 07:55 AM | #7 |
Dlux U4 truss....
02-05-2016, 01:45 PM | #8 |
First off, that truss looks wicked. If I was to get one for my Bomber, would I need to get different upper links? How about the steering linkage? Sent from my SAMSUNG-SGH-I337 using Tapatalk |
02-05-2016, 01:56 PM | #9 |
Pebble Pounder Join Date: Jan 2014 Location: Chester, WV
I prefer the Dinky servo mount. Much easier to install...That's just my opinion.
02-05-2016, 02:00 PM | #10 | |
There's a lot more to it than just a servo mount. Everything Erik covers in his post are why I got it, plus it looks badass. | |
03-30-2016, 10:50 AM | #11 |
Quarry Creeper Join Date: Dec 2009 Location: Cape Cod
VP just released this one piece servo mount. I ordered one yesterday to do with my new 7950 servo. Vanquish AR60 Axle Servo Mount Black Anodized - Vanquish Products |
03-30-2016, 01:48 PM | #12 | |
Quarry Creeper Join Date: Jul 2010 Location: The Ocean State
03-30-2016, 02:01 PM | #13 |
RCC Addict Join Date: Aug 2013 Location: Missoula
Doesn't really address the servo depth issue though... You really want the servo moved back as far as possible, till the horn just barely clears the mount and truss. Getting the horn moved behind the tie rod greatly improves servo life. Edit: If you install the mount backwards, and mount the servo from the rear it might work? Looks like that would actually be too far back. You would also have to either notch the mount, of grind off the tab on the front of most servo ears. Last edited by maslin; 03-30-2016 at 03:46 PM. |
03-30-2016, 03:46 PM | #14 |
Maybe if you flip that VP mount around and mount the servo on the back side.
03-30-2016, 03:50 PM | #15 |
I should have one in hand tomorrow to check out the possibilities. My geometry with the stock servo mount seems ok, the most it could go back while clearing the axle is 3/16". I could also try mounting the link on the back of the servo arm, but it might not clear the diff cover.
03-31-2016, 08:40 AM | #16 | |
Rock Crawler Join Date: Feb 2010 Location: Central/SE Ohio
03-31-2016, 10:36 AM | #17 | |
03-31-2016, 11:47 AM | #18 |
Newbie Join Date: Jan 2016 Location: Germany
thats the way we connect the steering servo to the external bec without routing the amps through the rx. |
03-31-2016, 11:52 AM | #19 | |
Rock Crawler Join Date: Nov 2013 Location: In the country
If im wrong id love to now the proper mounting because I love em! | |
03-31-2016, 01:15 PM | #20 |
Quarry Creeper Join Date: Nov 2010 Location: Queen Creek, AZ
I run a wraith servo dewanger plate with VP mounts and clamps, but the new VP mount is a better 1 piece option. Just add the clamps.
Steering servo mount options? - Similar Threads | ||||
What are the best Servo Mount options? | o0wiz0o | Axial Wraith | 17 | 03-15-2015 12:40 AM |
AR60 servo mount options | greenjk | General Crawlers | 5 | 07-04-2014 11:33 PM |
LF T-rex axle servo mount options | Dad,Canyoufix? | Axial SCX-10 | 0 | 04-17-2014 07:02 AM |
Steering servo mount | Swass | Axial Wraith | 5 | 10-02-2012 12:52 PM |
servo mount options w/o clocking links? | solomon7 | HPI Wheely King | 7 | 07-30-2007 10:31 PM |
